DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Mains light switch to dimmer
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
starwarsclark
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 05, 2007 3:28 pm    Post Subject:
Reply with quote Thanks
Hi I hope someone can help me out please. I have had a conservatory built and the electrician has fitted a double light switch that I wish to replace with a single dimmer switch. Now the wiring appears to be connected to the mains not the lighting circuit and when I took off the original double switch I stupidly did not note where the cables connected. The cables I have are: 1 x brown that comes up the wall, 1 x blue that comes up the wall and then 1 x brown that goes to the light, 1 x blue that goes to the light and 1 x grey that has a brown sleeve on it. My dimmer switch only has 1 x live (funny looking symbol) and 1 x L2 on it. Can someone please help me out and advise me as to what gets connected where. Thanks Andy. icon_redface.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat May 05, 2007 4:19 pm    Post Subject:
What does the light switch? Two seperate things?
Is there a three core and earth going upto the light, or two seperate cables?
Back to top
 Alert Moderators
starwarsclark
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 05, 2007 4:24 pm    Post Subject:
Thanks for the reply. The light switch is a 2 way individual switch as I could have chosen to have a ceiling mounted fan and light and then turned them on and off individually - I hope that makes sense. Going up to the light itself is 1 x blue, 1 x grey (with brown sleeve) and 1 x brown. There is also earth up there as well. I have, or had connected a new light to the fitting and it was all working fine it just went wrong when it came to actually fitting a dimmer style switch to replace the 2 individual switch that was there. When the 2 individual switch was orginally fitted I could turn the light on or off with either of the switches if needed. Does that all make sense? I hope so as I have a dinner party tonight and would love to finish the light off before people turn up!
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat May 05, 2007 4:38 pm    Post Subject:
Blues in a terminal block on their own (suspect one blue is actually a black with blue sleeve?)
Brown from below to COM, or the wiggle line.
The other two from the light (brown and sleeved grey) to the L1 terminal.
The brown and sleeved grey must be in the same terminal at the light, so need to be in the same terminal at the switch - a little odd, but fine to do.
Back to top
 Alert Moderators
starwarsclark
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 05, 2007 5:03 pm    Post Subject:
Thank you - now tried the above but no joy still.
To confirm:
I have the brown from below is connected to COM or wiggle line.
I have joined the 2 blues togwther with a terminal block (1 from below is blue the one that goes to the light pendant is actually a black with a blue sleeve.)
I have connected the brown and grey that come from the light together in L2 on the dimmer switch as there is no L1 on the dimmer switch I have ( it only has the wiggle line and L2)
Finally I have connected the blue cable to one side of the pendant and then joined the brown and grey together in the other side of the pendant.
Still no joy though.
What am I doing wrong?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sat May 05, 2007 5:18 pm    Post Subject:
nothing, that should work.. turned the breaker back on?
is the dimmer the right sort for the light?
what type of light is it?
what's your location? if i hadn't already had a bottle of wine i could come round if you're near me...
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat May 05, 2007 5:24 pm    Post Subject:
Just to check, did you connect, at any time, the blue wires to the dimmer switch? The wiring given by lectrician should have worked, unless you have blown the dimmer.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sat May 05, 2007 5:26 pm    Post Subject:
unless the dimmer needs a neutral.. some types do...
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat May 05, 2007 5:27 pm    Post Subject:
Back to top
 Alert Moderators
starwarsclark
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 05, 2007 5:37 pm    Post Subject:
Sorry I have to turn the PC off to try the very kind suggestions all of the you are giving me. Still no joy though.
I will give up on the dimmer for the moment and go and use a normal 1 switch so could someone please confirm for me how to wire a normal 1 switch switch based upon the wires I have.
Thanks again for everyones help.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat May 05, 2007 5:46 pm    Post Subject:
Same way as above.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Sat May 05, 2007 5:47 pm    Post Subject:
same as the dimmer..
blues in a block.
brown from below to COM or ~
brown and grey from light into L1...
Back to top
 Alert Moderators
starwarsclark
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 05, 2007 5:57 pm    Post Subject:
You lot have been great but still no joy at my end. I am going to have to give up now as guests are due here in about 10 minutes and I haven't even changed yet! Will get back onto it tomorrow or just wait til Tuesday and ask the electrician that did the original wiring. Really frustrating this as it should not be hard. Thanks again you lot. Have a great weekend.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat May 05, 2007 6:42 pm    Post Subject:
Squished a wire and blown a fuse?
Is there a fuse spur somewhere near to a socker? Can be common to find this in a conservatory extension (eaier to wire). This sounds likely as the cable comes from below, and you mention it isn't fed from the lighting circuit, but 'the mains'.
Back to top
 Alert Moderators
starwarsclark
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 06, 2007 12:33 pm    Post Subject:
Hooray sorted it out!
Turns out that there was a fuse further down the line, behind some furniture, so replaced that and got the original switch working. Connected the dimmer switch and nothing, so the dimmer switch was faulty as well. Bought a new one and away we go.
As I said yesterday you lot have been brilliant and saved me contacting the electrician, so thank you so much.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Dimmer switch what one for 10 mains downlighters ? 8 760 Mon Jun 27, 2005 11:02 am
Warm Dimmer switch mains voltage halogens 4 420 Fri Oct 26, 2007 6:13 pm
Dimmer Switch on mains fluorescent downlighters? 6 160 Tue Jun 09, 2009 10:47 am
Wiring dimmer from mains 9 500 Tue Dec 30, 2003 3:43 pm
mains halogen and dimmer load 2 280 Mon Mar 13, 2006 7:43 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
