ellsbells
Joined: 07 May 2007 Posts: 1 Location: Kent, United Kingdom Thanked: 0 times
Robert too
Joined: 05 May 2007 Posts: 129 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Mon May 07, 2007 7:49 pm Post Subject: |
I will be interested in seeing the responses from the guys actually doing it ,
as a specifier , i always ask for concrete blocks as an outer skin to receive render |
noseall
Joined: 02 Feb 2006 Posts: 11058 Location: Staffordshire, United Kingdom Thanked: 73 times
Posted: Mon May 07, 2007 8:26 pm Post Subject: |
i for one would not use lightweight (high suction) blocks on an external situation.
saturate the blocks with a garden hose.
good luck. |
Ron Gamma
Joined: 06 Apr 2006 Posts: 143 Location: London, United Kingdom Thanked: 0 times
Posted: Tue May 08, 2007 1:37 pm Post Subject: |
I'm keen to know the answer as well.
I'm about to render some medium density blocks and want to avoid a c*ck-up.
Usual rendering style consists of trying to press it on with a trowel gradually descending to standing about 3 foot from the wall and lobbing handfuls of muck at it until it stays put. |
brist
Joined: 17 Dec 2006 Posts: 265 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Tue May 08, 2007 4:38 pm Post Subject: |
SOAK THE WALL MIX 4 TO 1 AND ADD A CAP FULL OF OPTIMIX TO EACH MIX. |
jamcb
Joined: 14 May 2007 Posts: 4 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Mon May 14, 2007 9:50 pm Post Subject: |
hi, i suggest you contact thermalite technical department and submit the question to them, they will for sure give you the correct advice. |
claude76
Joined: 05 Jun 2007 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Tue Jun 05, 2007 7:57 pm Post Subject: |
wet your wall do a 3 sand 1 cement mix render your wall then get a piece of wood about 6inches long hammer nails through it and scratch the render moving along in a wave motion.then leave to dry and do a second coat this is your finish coat.the first coat is to take out any uneven bits sticking out or holes etc that need filling.if u do one coat u normally see the block shapes through it once it dries but also depends how thick u put it on.normally u do 2 coats also seals it better. |
