DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Extending Micro Bore system without using manifold
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
dja
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 08, 2007 2:50 pm    Post Subject:
Reply with quote Thanks
I wish to add 2 radiators (in an extension)to our Combi powered micro bore central heating system , but to save a lot of work getting access to the manifoilds (under floor in main part of house)and running excess pipework can I tap a 15mm pipe (and then branch to 10mm to the 2 rads)from the 22mm flow and return pipes near the boiler to provide for this.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
clf-gas
from United Kingdom
Thanked: 25 times
PostPosted: Tue May 08, 2007 3:18 pm    Post Subject:
Yes if you balance the rest of the system to cater for the addition.
__________________
STUPID = Smart Talented Useful Person In Demand
Back to top
 Alert Moderators
dja
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 08, 2007 3:30 pm    Post Subject:
Thanks Craig, I guess that as long as the system is fully balanced then you can mix manifold sytems with 'traditional' system design?.
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 5 times
PostPosted: Tue May 08, 2007 3:40 pm    Post Subject:
The principle of the microbore manifold is to ensure easy balancing. You may find that, by connecting into the main f&r near the boiler it will cause problems in trying to re-balance the existing circuits served by the manifold. The balancing valves on the new radiators may have to be shut down so much that you may get noise problems through these rads.
Back to top
 Alert Moderators
dja
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 08, 2007 4:34 pm    Post Subject:
Thanks Giblets, I understand what you are indicating. What I'm trying to avoid is running 40ft of 10mm pipe from the current manifold which is way over on the opposite side of the house from the boiler when the extension is right next to the boiler. I'm hoping to reduce the pipe length to 20 ft of 15/10mm pipe by avoiding the manifold and going a more direct route from the 22mm Feed/Return pipes near the boiler.
Back to top
 Alert Moderators
dja
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 10, 2007 10:36 am    Post Subject:
Any further thoughts from anyone...I'm getting close to starting work. Thanks
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Dumping manifold off underfloor heating system? 10 300 Sun Apr 26, 2009 5:28 pm
manifold/microbore system problems 3 3320 Wed Dec 28, 2005 6:11 pm
Maincor radiator manifold system 6 120 Thu Sep 10, 2009 9:29 am
Extend Feed-and-return system with manifold/microbore? 5 1160 Thu Nov 25, 2004 1:22 pm
Micro Bore system - should I convert? 4 120 Sun Nov 01, 2009 9:21 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
