Joined: 10 May 2007 Posts: 3 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Thu May 10, 2007 10:03 am Post Subject:
radial circuit
need more sockets in property.have four separate radial circuits 1 kitchen 2 lounge&dining 3 two main bedrooms 4 two guest bedrooms and small office. all run from consumer in 6mm cable then junction boxed down to 4mm directly above consumer.each circuit runs six double sockets, need eight maybe more on each.can i junction box in 4mm for additional sockets or is this system outdated and better to replace with 2.5mm rings ? all wiring looks new in good condition and checked by meb in 2002.
Joined: 17 Nov 2006 Posts: 1680 Location: West Glamorgan, United Kingdom Thanked: 0 times
Posted: Thu May 10, 2007 11:37 am Post Subject:
Am I right in assuming you mean there is a single 6mm˛ cable going to a junction box where all the radials come from or are there separate 6mm˛ cables for each junction box/radial circuit? What size fuse/MCB is this 6mm˛ cable connected to?
There is nothing wrong with radial circuits but the use of junction boxes should be kept to a minimum. If you can give more info on how the wiring is currently organised we might be able to offer a simple solution to your problem.
Joined: 18 Jan 2007 Posts: 1241 Location: Yorkshire, United Kingdom Thanked: 4 times
Posted: Thu May 10, 2007 11:39 am Post Subject:
I would attempt to get rid of junction boxes and replace with 2.5t&E.
You can have an unlimited number of sockets on a radial as long as no appliance exceeds 20A (the OCD). This is assuming a floor area of less than 50m squared for each radial.
If you're prepared to redecorate (a little) I would go for Final Rings myself, as they are easy to extend.
For greater detail look in OSG page 151 table 8A
and page 156 gives recommended number of oulets per room
Joined: 27 Feb 2007 Posts: 260 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Thu May 10, 2007 1:50 pm Post Subject:
mr JohnD
There was a call out for you last night on the bathroom illuminated mirror post? was kinda looking forward to your response on it all, but hey I understand if you are a busy bee. I have noted you are a knowledgable man (read some of your responses and posts on the plumbing section), pretty impressive i must say. Keep up the good work, this site needs more individuals like you mate.
Posted: Thu May 10, 2007 8:22 pm Post Subject:
Thanks for your replys. each circuit has 6mm cable running vertically for around 2 metres then junction boxed down to 4mm under bedroom floor. why not run all in 4mm? cable then runs into each room and junction boxed off to each socket .each circuit on 32 breaker and biggest floor area covered is around 35m2. hope this makes sense !!!!!!!!! thanks
Posted: Thu May 10, 2007 8:29 pm Post Subject:
Tut tut...
Junction boxes should be accessible, so if you are doing work on the circuit you might want to get shot of them and wire each socket in a daisy chain fashion... If you are not comfortable opening up the CU then leave the 6mm˛ but move the junction box somewhere accessible, then go down to 4mm˛ cable and wire the sockets as below...
Joined: 11 Jan 2004 Posts: 16480 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Thu May 10, 2007 8:40 pm Post Subject:
I personally believe radials are far easier to extend, cannot be f*d about with & if 20A is not big enough, go large to 32A and up the cable to 6 milli...
__________________ As George Michael once said, "..if you're gonna do it, do it right, right?"
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
