DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
shower pump location
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
darenmul1
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 11, 2007 3:23 pm    Post Subject:
Reply with quote Thanks
can anyone tell me if it would be okay to take a hot feed for the pump from the main
hot pipe that feeds the rest of the house.
i know it should have its own feed from the cylinder but my cupboard is tiny and i cant see where a new pipe would fit in. i am having to fit the pump in the loft below the cold tank. HELP.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Fri May 11, 2007 3:40 pm    Post Subject:
The shower pump should be fitted at the base of the H/W cylinder and the hot supply should not be teed off the present hot supply. You need to change the 22mm outlet on the top of the cylinder to a surrey flange which gives 2 seperate outlets for hot water and run the side outlet to your pump. The cold for your pump should come direct from your cold tank in the loft indepentently.
Shower pumps need to 'push' the water rather than 'pull' as you are hoping to do.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
darenmul1
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 11, 2007 6:21 pm    Post Subject:
thanks dave i know the pump is supposed to go at the base of the hot cylinder but in my cylinder cupboard its a physical impossibility as its so tight at the bottom.the pump i have is a watermill pc70, is there any way to get it to work sited above the cylinder.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Fri May 11, 2007 6:25 pm    Post Subject:
I am not an expert in shower pump installations. I only know the basics which you appear to know but cannot install to. Perhaps another on here can advise you better icon_wink.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Sat May 12, 2007 12:02 pm    Post Subject:
Is there any other space, under a bathtub, for for instance, where you could install the pump?
(That should get the electricians doing somersaults! icon_smile.gif )
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
shorky
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 12, 2007 1:59 pm    Post Subject:
yes, you can fit at the base of the bath,(not sure about electrical regs) or above the cylinder, keep it as close to the cylinder as can be, follow ALL of the remarks Gas 4 You made, bear in mind you need a minimum flow rate to operate a standard pump, this means follows all Mi's, and clearances from base of C/W tank and highest outlet icon_exclaim.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Shower pump location 5 580 Sun Oct 28, 2007 10:31 am
Shower pump location / type 14 1220 Tue Oct 09, 2007 5:14 pm
location for single impeller pump for HW 2 600 Sun Oct 15, 2006 10:08 am
CH pump location 21 1780 Sun Aug 13, 2006 8:40 am
Closed loop cirulation pump optimum location 2 140 Mon Oct 20, 2008 7:54 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
