Basils57
Joined: 18 Apr 2004 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Wed Apr 21, 2004 10:38 pm Post Subject: Washing M/c Waste |
Is there any problem with running the drain hose of a washer into a special sink trap waste with a 'spur', by securing it with a jubilee clip? |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Thu Apr 22, 2004 6:05 am Post Subject: |
yes, they are rubbish, the spiggot you refer to will collect lint and block up, causing your m/c problems, stand pipes are much better __________________ Do you like music Mr Finch?
Forum = Opinions |
IanDB
Joined: 26 Nov 2003 Posts: 750 Location: Dorset, United Kingdom Thanked: 0 times
Posted: Thu Apr 22, 2004 8:16 am Post Subject: |
Being fair though Breezer, they do work. I've had my m/c connected that way for 6 years and never had a problem. Stand pipes are better but if you are aware of the problems you might encounter with the "spigot" method you might as well use it if that's the easiest way. |
universe
Joined: 12 Jan 2004 Posts: 14 Location: United Kingdom Thanked: 0 times
Posted: Thu Apr 22, 2004 3:15 pm Post Subject: |
Hi
The safe/clear-cut option is to connect the outlet drain pipe to the main drain pipe as a separate outlet and to set the outlet tube to drain pipe connection at the correct height as shown in the manuals - drain pipes can block and flood the premises when least expected! So . . . if you have the freedom/choice/option to connect separatetly then please do so.
Good luck.
Archie |
Basils57
Posted: Sun Apr 25, 2004 7:57 am Post Subject: |
Thanks for the advice folks. As running into a spigot is far more convenient I will be doing that - but noting and watching for the possible problems. |
