cpainter
Joined: 15 May 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Tue May 15, 2007 1:32 pm Post Subject: two way into one way switching |
I have a room with a light controlled by two switches - one by each door. I want to take out one swithch and turn the other into a one way switch. each switch has a red into each L1 and L2 and a black into common. How do I do it please? |
ColJack
Joined: 16 Feb 2007 Posts: 7599 Location: West Midlands, United Kingdom Thanked: 129 times
Posted: Tue May 15, 2007 5:19 pm Post Subject: |
not entirely sure that's right.... should be red and black into L1 and L2 respectively, with a single red into COM on both...
unless they are using singles or a twin red and a single black at each.. but why would they do that?
anyway.. the way it's wired you cannot "take out" a switch,
you can remove the switch and connect the COM and L1 of one switch in a terminal block, with the spare cable in a seperate connector block, and then blank off the switch, but the cables and box must remain..
unless you pull the cables back up / down into the ceiling / floor where you can connect them in a junction box as described, but this must remain accessible ( ie not under a laminate / tiled floor and with an access hatch over it ) |
cpainter
Posted: Tue May 15, 2007 5:37 pm Post Subject: Two way to One |
OK can do that, but then want to wire-up remaining switch in a new single gang. Which of the three wires do I leave off? |
ColJack
Posted: Tue May 15, 2007 8:54 pm Post Subject: |
whichever one you didn't connect into the conector block...
( it's 2 reds, how am I supposed to define a difference between them? )
get a multimeter ( available for about £15 from the DIY sheds ), read the instructions for it, then continuity check from end to end... |
