DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Cooker hood on 2.5mm cable
This topic originated from the How to page called Installing a cooker hood
Click here to return to the page called Installing a cooker hood.
Author Message
exeter
from United Kingdom
PostPosted: Tue May 15, 2007 2:13 pm Reply with quote
Hello all.
I have a fused connection unit, which I presume spurs from the ring main, because it is connected to a single T&E cable and when I remove the 30amp fuse which I know protects the ring, the supply stops.
Before plastering, I ran a 2.5mm T&E from this FCU (vertically, then horizontally) so I could then connect a flex outlet and then a cooker hood. I now know I should have used 1.0mm T&E, but have heard that using larger cable is safer than using too small a cable.
Does anybody forsee problems using 2.5mm between the FCU and the flex outlet, and a 3A fuse in the FCU?
Cheers
Back to top
 Alert Moderators
RobFurn
from United Kingdom
Thanked: 1 time
PostPosted: Tue May 15, 2007 2:45 pm Reply with quote
No problem with 2.5 from your FCU to your cooker hood, What does concern me is the vertically and horizontally bit in your thread. Are you aware of Safe Zones?
Back to top
 Alert Moderators
Chri5
from United Kingdom
Thanked: 320 times
PostPosted: Tue May 15, 2007 2:46 pm Reply with quote
No that's fine, most would do the same.
The majority of all socket based ring circuits and spurs are always in 2.5TE
With smaller cable you are saving pennies and loosing the ability to increase the load on the spur device, should something heavty ever replace the current hood.
Kitchen electrics are notifiable under Part P as a special area.
Back to top
 Alert Moderators
exeter
from United Kingdom
PostPosted: Tue May 15, 2007 3:26 pm Reply with quote
thanks for your replies - I know you're not allowed to embed cable diagonallly and within 150mm of the edge of a wall, shoiuld I have run it horizontally, then vertically?
Back to top
 Alert Moderators
RobFurn
from United Kingdom
Thanked: 1 time
PostPosted: Tue May 15, 2007 3:37 pm Reply with quote
Draw us a picture of where you have placed your cables and we will tell you if its ok.
I would post you a picture of the safe zones but I dont have one to hand however no doubt someone will be along in a bit to post one.
Back to top
 Alert Moderators
sm1thson
from United Kingdom
PostPosted: Tue May 15, 2007 4:04 pm Reply with quote
Back to top
 Alert Moderators
exeter
from United Kingdom
PostPosted: Tue May 15, 2007 7:28 pm Reply with quote
I routed the cable vertically from the FCU a couple of feet and then horizontally, at a right angle, a couple of feet, in line with the flex outlet. So the flex outlet is on a diagonal line from the FCU, but the cable is routed at a right angle.
If this is wrong, how does one route the cable from an fcu to a flex outlet that is not in the vertical above it? Use metal conduit?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Tue May 15, 2007 9:18 pm Reply with quote
that's fine..
you can go horizontally or vertically from an accessory..
which is exactly what you have done.
Back to top
 Alert Moderators
daytona
from United Kingdom
PostPosted: Mon Jun 09, 2008 6:48 pm Reply with quote
OP
the only thing i would say is,keep an eye on how you join the flex to the 2.5 twin and earth,check that the flex doesnt come apart from te connections,double the ends over.
EDIT:
just re read your post and your using a flex outlet plate,so no probs there either.
mrspiers,you havent given us any information regarding the load of said oven or how you intend to run the cable,or anything for that matter.
might be a good idea to start your own thread instead of hijacking someone elses icon_wink.gif
Back to top
 Alert Moderators
Moderator 9
Moderator Comment
Posted: Mon Jun 09, 2008 7:00 pm    Comment:
Hijack topic split
Page 1 of 1
Jump to:
Cable for cooker hood 3 740 Sun Sep 09, 2007 10:02 pm
concealing cooker hood cable 4 740 Thu May 06, 2010 6:03 pm
cooker hood power rating in watts? 3 560 Fri Jun 17, 2005 6:37 pm
Cooker hood questions 4 40 Wed Mar 07, 2012 10:05 pm
Hob ignition and cooker hood 5 580 Fri Jun 17, 2005 9:39 pm
DIYnot
