DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wiring new oven and hob
This topic originated from the How to page called Installing an electric cooker
Click here to return to the page called Installing an electric cooker.
  View previous topic :: View next topic
Author Message
exeter
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 15, 2007 2:28 pm    Post Subject:
Reply with quote Thanks
Hello -
My old hob and oven were both wired into a terminal outlet that was screwed into the back of the kitchen unit, and was, in turn, wired with 6mm cable to 45A cooker control unit. The CCU is on a 6mm radial from the consumer unit, protected by a 30amp, single-bladed, fuse.
My question is, if the oven runs at 2.3KW and the hob 5kW (around 32A) can I wire both flexes into the terminal outlet again? Or should I run two cables from the CCU, one 6mm to a terminal outlet for the hob, the other 2.5mm (or smaller) to a flex oulet, for the oven.
There is a nearby FCU and single socket within the same double back box, both separately spurred from the ring. I plan to use the FCU for the cooker hood and need the socket free. Could I install 2 FCUs instead, to feed the hood and the oven, then install a CCU with a socket, since the hob is not that powerful?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 15, 2007 2:59 pm    Post Subject:
You can connect the hob and oven to the outlet you currently have available as long as the flex used it rated at, or above the fuse rating. If you do this you can use the fused spur for the cooker hood and the socket will be free.
You should never connect a cable to a circuit unless the CCC of that cable meets, or exceeds the fuse rating - so you can not use 2.5mm˛ or smaller cable from the CCU to feed the oven.
Back to top
 Alert Moderators
exeter
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 15, 2007 4:23 pm    Post Subject:
The oven came with a flex - 1.5mm I believe. The hob instructions specify a similar flex. I shall check their ratings. Hopefully I can wire them both to the terminal outlet. The CCU is a standard 45A and the radial circuit is 30A.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Wiring for oven / fan please 4 120 Sun Oct 04, 2009 7:30 am
New Wiring for separate Hob & Double Oven 44 1020 Mon Oct 12, 2009 9:05 pm
wiring bosch double oven 5 1220 Sat Nov 17, 2007 3:13 pm
Double Oven Wiring 6 160 Fri Aug 28, 2009 9:58 am
Wiring an Electric Oven 4 780 Fri Apr 21, 2006 9:17 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
