Joined: 16 May 2007 Posts: 4 Location: Armagh, United Kingdom Thanked: 0 times
Posted: Wed May 16, 2007 12:10 pm Post Subject:
Wiring electric oven
Hi. My terminal outlet box behind the oven already has two sets of wires running into it. One that presumably comes from the radial circuit. The other that comes from "somewhere behind the plaster"! The wires are only live when I switch on the control unit. Presumably, I can just wire my new oven into the terminal outlet box as normal? Thanks, Paul.
Posted: Wed May 16, 2007 1:10 pm Post Subject:
Thanks for your quick reply, Crafty. I'm at work at the moment and don't know the rating of the oven or the unit. The new appliance is a double electric oven with electric hob. There is no separate hob, so that doesn't solve the mystery of the additional wire (yet!). Paul
Joined: 15 Apr 2005 Posts: 12859 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Wed May 16, 2007 1:18 pm Post Subject:
You really need to find what that wire feeds. Turn off the circuit and see if theres anything in the kitchen that doesn't work. Test all the sockets with a known working lamp.
If you're then certain it no longer feeds anything, by all means disconnect it from that box, and remove it so nobody reconnects it.
Posted: Thu May 17, 2007 8:54 am Post Subject:
Didn't get a chance to check the rating of the oven or fuse. However, I did identify that the 'mystery wire' feeds a socket in the shed which is currently serving the tumble dryer!
Posted: Thu May 17, 2007 7:19 pm Post Subject:
That wont do I'm afraid.
A tumble dryer is a high-load appliance (in 13 amp plug terms), and therefore should not be on a cooker circuit, and especially not this side of the cooker switch!!!
How easy would it be to re-arrange power to the shed?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
