DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wiring bathroom extractor to old fashioned lighting circuit
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
Author Message
exeter
from United Kingdom
PostPosted: Thu May 17, 2007 4:13 pm Reply with quote
My lighting circuit wiring is very old. In the bathroom I have three wires, sheathed in fabric that come from metal conduit. One wire is a switch live, another one permanent live and the third is neutral.
In the bathroom light fitting (not loop-in) switch live is in one terminal and neutral and permanent live are joined together in the other. If you disconect permanent live, then the bathroom light will work, but some of the other lights in the flat stop working - so i\\\'m presuming that the permanent live is a circuit cable.
I have an extractor fan with timer which I want to make sure will work before incorporating an isolating switch. I want it to come on with the light switch and over run and I also want the bathroom lights and other lights to work, obviously.
The fan works perfectly if I connect the three wires appropriately, and I presume I could get the bathroom light to work, but because the permanent live and neutral are separated, half the lights in the flat stop working.
What I\\\'m wondering is if there is a way to solve this problem, or should I buy a non-timer fan instead. Would this type of fan only have two terminals - a switch live and neutral?
Could I therefore just extend a twin and earth cable from the light fitting and wire up the fan to work with the light switch, while keeping the permanent live and neutral together at the light fitting?
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
PostPosted: Thu May 17, 2007 4:38 pm Reply with quote
You do not have a neutral and permanent live in one terminal because that would create a dead short and the fuse/MCB would blow/trip.
Some pictures or a clear explanation of the number of cables present, along with the number and colour of conductors present at the switch and light in the bathroom would help greatly.
By the way. work in the bathroom is notifiable, so before you start fiddling you need to notify your BCO and pay the relevant fees for them to inspect and test.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 136 times
PostPosted: Thu May 17, 2007 5:16 pm Reply with quote
If you have the old cloth covered rubber cables, then I would not be surprised if the insulation is perished or hard & cracking, personnaly I would not consider doing any modifications to the circuit unless I was 100% certain it was safe, which means having it tested professionally.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 738 times
PostPosted: Thu May 17, 2007 5:37 pm Reply with quote
You need to call an electrician.
If you really do have VIR singles in conduit, then this all needs replacing ASAP
The 'permanant live' is infact a neutral which appears live as you have broken the continuity from the remaing light back to the mains.
No offence but you are way out of your depth.
Please can we have some photos of your wiring and also your fusebox and mains inccomer area so we can get a better idea of what state your wiring is really in.
Back to top
 Alert Moderators
exeter
from United Kingdom
PostPosted: Thu May 17, 2007 7:01 pm Reply with quote
The sparks from work said he'd take a look.
Rest assured, my consumer unit is of the single-bladed fuse variety and the light switch to the bathroom looks like spaghetti junction. Thankfully it is located outside the bathroom.
They are VIR singles coming out of conduit. The one I referred to as switched live is red, the other two are black. The reason I thought one was permanent live is that when I wired up timed extractor fan, it ran the timer over-run ok, whereas the switched live switched it on.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 738 times
PostPosted: Thu May 17, 2007 7:34 pm Reply with quote
exeter wrote:
Rest assured, my consumer unit is of the single-bladed fuse variety.
Back to top
 Alert Moderators
exeter
from United Kingdom
PostPosted: Thu May 17, 2007 9:28 pm Reply with quote
I was being facetious! The place is in need of a rewire, but until I find the £3-4,000 to do it, the VIR cables and 50 year old fuse box will have to soldier on. Will get it tested before I get any further work done, though.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
old fashioned Fuse-boards 17 1140 Wed Jan 07, 2009 2:20 pm
old fashioned fusebox !!! 9 1380 Tue Sep 12, 2006 8:18 pm
Old fashioned fusebox 4 420 Thu Mar 18, 2010 1:17 pm
Wiring an extractor fan into a bathroom lighting circuit. 6 6520 Fri Mar 12, 2010 12:13 am
Extractor fan in bathroom not on lighting circuit? 3 80 Wed Jun 13, 2012 3:16 pm
DIYnot
