DIYnot
Local | Network
   DIYnot > Forums
Local | Network
boiler runs for 30 seconds then cuts out
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
peely
from United Kingdom
PostPosted: Sun May 20, 2007 8:54 am Reply with quote
Hi
I have recently fitted isolation valves in the feed and return to my Optia ff50 boiler, I also replaced the pump at the same time. The boiler now runs for a short time (30 seconds) before cutting out, it then sounds like water is trickling into the boiler, after about 5 minutes the boiler fires up for another 30 seconds then shuts down again.
All rads/system have been bled and refilled.
I am thinking that the bore of the isolation valves could be the problem?
Any thoughts
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 485 times
PostPosted: Sun May 20, 2007 8:57 am Reply with quote
Have you put the new pump on the right way around.
Back to top
 Alert Moderators
peely
from United Kingdom
PostPosted: Sun May 20, 2007 9:00 am Reply with quote
wow
thanks for the fast reply
just had a double check and the big arrow on the side points the same way
peel
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3438 times
PostPosted: Sun May 20, 2007 9:06 am Reply with quote
peely wrote:
wow
peel
Same way as what?
If you hear a trickling sound then that implies there is air inside and its not full of water! Bleed points???
Tony
Back to top
 Alert Moderators
peely
from United Kingdom
PostPosted: Sun May 20, 2007 9:22 am Reply with quote
I have bled everything "bleedable", several times,
I have just double checked the the manual bleed on the "rad side" and just cracked the auto bleed on the hot water side, both full of water.
Both are higher than the boiler, do you think I may need a bleed point closer to the boiler ?
Pump is wired up the correct way as well.
thanks for the help
Peel
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 774 times
PostPosted: Sun May 20, 2007 9:25 am Reply with quote
Do you get air/water out of upstairs rads? Is f&e tank full?
If so turn h/w on at timer, turn boiler off at stat, turn pump speed up to max and try to push air lock out to vent. Then try this with jusy ch on and only 1 rad left on, then do each rad in turn and see if this helps icon_wink.gif
Back to top
 Alert Moderators
peely
from United Kingdom
PostPosted: Sun May 20, 2007 9:31 am Reply with quote
getting water out of the rads, bit I'll give it a go
seems that I am looking at an airlock rather than a valve problem?
I might fit a bleed valve just above the boiler if I still get probs?
what do ya think?
Cheers
Peel
Back to top
 Alert Moderators
joineryisahobbynotatrade
from United Kingdom
PostPosted: Sun May 20, 2007 9:49 am Reply with quote
The trickling sound does sound like air.Bleed the pump and stick a screwdriver in to make sure it does not stuck CRUNCH CRUNCH
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Oil-fired boiler fires, runs for 75-150 seconds, cuts out 3 660 Mon Nov 23, 2009 2:31 pm
Pilot light on CH boiler cuts out after seconds 10 140 Wed Oct 09, 2013 8:59 am
flame cuts out after 5 seconds on baxi combi 100he 2 540 Mon Feb 18, 2008 9:23 pm
Baxi Bermuda cuts out after 30 seconds 3 820 Sun May 02, 2004 12:25 pm
Baxi Bahama 100 cuts out after 8-9 seconds 11 680 Fri May 22, 2009 3:04 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
