DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wax on Velvet drawer lining
This topic originated from the How to page called Candle Wax
Click here to return to the page called Candle Wax.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
CPOConnecticut
from United States of America
Thanked: 0 times
PostPosted: Mon May 21, 2007 5:11 am    Post Subject:
Reply with quote Thanks
Help I need to get wax out of my velvet drawer liner...anyone help?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Scrit
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 7:15 am    Post Subject:
Ice cubes in plastic bag, hold against wax to freeze it then comb out with nylon comb. May need to be repeated several times. Success not guaranteed because of the fine nature of velvet and the fact that you cannot flex the material to break-out the wax particles
Scrit
__________________
Measure twice, cut once - except fingers!
Back to top
 Alert Moderators
trazor
from United Kingdom
Thanked: 3 times
PostPosted: Mon May 21, 2007 12:15 pm    Post Subject:
Scrit,s idea is probably the best.....But if that fails try putting blotting paper over it then a warm iron.
It will soak some up, but how much..???
Back to top
 Alert Moderators
Scrit
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 4:45 pm    Post Subject:
I'm not sure aboput applying heat simply because I'd be concerned about causing the wax to sink even further into the material.
Another possibility might be to use gentle heat and turpentine as turps is used to dissolve waxes to make traditional wax polishes, however it does niff a bit, it can leave and oil stain and it does have a pretty low flash point..... I'd still try freezing out first as that's what dry cleaners do (and is where I got the tip, although my local dry gleaner uses liquid CO2 to get rid of wax and chewing gum by making it son brittle it just splinters when the material is folded)
Scrit
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
quick q regarding drawer alignment 6 200 Tue Oct 06, 2009 8:20 pm
My Kitchen drawer fronts are falling off 10 2660 Tue May 13, 2008 6:48 pm
Remove Ikea Faktum Drawer Front 2 2620 Mon Feb 26, 2007 11:06 am
Chimney lining? 5 960 Sun Sep 10, 2006 8:35 pm
Lining a chimney 2 520 Thu Mar 06, 2008 9:58 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
