DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Random switch/socket in bedroom; what is it for?
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
andyscc
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 4:23 pm    Post Subject:
Reply with quote Thanks
I recently move into a new house and in each bedroom there is a switch (at the usual socket height just above the skirting) which doesn't appear to do anything. They are not next to any other sockets and are located where I would expect to find a single socket in each room.
I unscrewed the switch to see if it was wired in and there is a single cable (30A I think) connected to it. The cable has red, black and earth without any tape on the black to indicate that it is a switch cable.
As a test, I connected a single socket to it but nothing that I plug into it works. I have checked the other sockets in the room and they are all fine; one in each room has 3 cables instead of the usual 2.
Could anybody suggest a purpose for these switches/sockets or how I could test to what they are?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
electronicsuk
from United Kingdom
Thanked: 23 times
PostPosted: Mon May 21, 2007 4:25 pm    Post Subject:
Are you sure they aren't switched spurs/fused connection units from an old electric storage heater installation?
Back to top
 Alert Moderators
andyscc
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 4:28 pm    Post Subject:
The house has central heating which has been installed since it was built in 1985 so I don't think that is what they are for.
Back to top
 Alert Moderators
electronicsuk
from United Kingdom
Thanked: 23 times
PostPosted: Mon May 21, 2007 4:29 pm    Post Subject:
In that case, can we have a picture? The fact that one socket in each room has three cables suggests these switches are simply spurred off the ring main, although whatever they were intended to power is no longer connected. This doesn't answer why you get nothing when you connect a single 13A socket, though.
Do the switches have a fuseholder? If not, are there any indications that they aren't normal light switches, such as 'ON' markings or a neon indicator?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon May 21, 2007 4:34 pm    Post Subject:
Is it a switch or a double poled isolator with flex outlet?
From what you describe it does sound like storage heaters. Do you have 2 fuse boxes?
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon May 21, 2007 4:37 pm    Post Subject:
Storage heater in a bedroom? Unusual. Panel heater maybe.
A photo would be good.
Out of interest, how may CU's go you have? A photo of them would be good too.
Back to top
 Alert Moderators
sparkyspike
from United Kingdom
Thanked: 17 times
PostPosted: Mon May 21, 2007 5:56 pm    Post Subject:
If these switches are definitely dead, then you may find the other ends of the cables at or near your fusebox. Any sign of a second meter or fusebox having been present at some time?
__________________
Are those my feet?
Back to top
 Alert Moderators
andyscc
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 7:11 pm    Post Subject:
Thank you all very much for your help.
Spark123/SparkySpike, there is a second fuse box next the the main box that doesn't do anything when the switch is turned off. I have unscrewed the panel and there are 2 live fuses, one marked PEAK and the other OFF.
I presume that this means the house used to have storage heaters; if this is the case, can I turn these switches into power sockets?
Back to top
 Alert Moderators
Gaz the Sparky
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 7:20 pm    Post Subject:
No unless you can find the cable and disconnect it from the off peak board and connect it to the normal tariff board
__________________
Lick this cable and tell me if its live
( a very very bad idea)
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
New Consumer Unit RCD tripping at random 20 3660 Fri Oct 05, 2007 10:30 pm
RCCB keeps tripping at random times 8 860 Mon Feb 23, 2009 4:02 pm
A question about CU Earth (and others random wonderings...) 14 1120 Mon May 08, 2006 4:14 pm
More random electrics DIYNOT pictures!!! 16 2260 Tue Aug 07, 2007 1:59 pm
Random plastic surface box question ? 3 480 Wed Jun 13, 2007 5:58 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
