DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
old and new nuts
This topic originated from the How to page called Plumbing in a cistern
Click here to return to the page called Plumbing in a cistern.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
malvo
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 22, 2007 4:34 pm    Post Subject:
old and new nuts
Reply with quote Thanks
Hi, Ive just fitted a new cistern inlet valve, but the nut from the old pipe (connecting the water pipe to the new one, under the cistern)will not seal completely, perhaps it\\\'s imperial and new metric. How do I solve this problem please?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chr15
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 22, 2007 4:42 pm    Post Subject:
Re: old and new nuts
Make sure the fibre washer is in good condition-if not change it-failing that fit a flexi pipe which would mean cutting the pipe below the cistern and fitting the flexi connector-you can get a pushfit or compression for the copper pipe end. icon_wink.gif
Back to top
 Alert Moderators
malvo
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 23, 2007 3:49 pm    Post Subject:
icon_surprised.gif Thanks, problem is really between the plastic screw pipe coming from the bottom of the inlet valve joing to the metal water pipe (small U bend), the nut is metal, it does not seem to make a complete seal, is there a sealing compound on something such? icon_confused.gif
Back to top
 Alert Moderators
Breesey
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 23, 2007 5:20 pm    Post Subject:
The threads should be the same. Make sure you aren't getting the nut cross threaded on the inlet, if you are it won't seal; and you could b*****r it beyond use. Also ensure your fibre washer is in good nick (ie use a new one).
Back to top
 Alert Moderators
malvo
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 24, 2007 7:39 am    Post Subject:
icon_redface.gif sounds as if my problem is this fibre washer, I don't have one, where should it be? icon_confused.gif
Back to top
 Alert Moderators
chr15
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 24, 2007 7:48 am    Post Subject:
It sits on the end of the fitting where your brass swivel nut connects to your plastic valve inlet--if the nut cross threads you won't get it to seal properly so make sure the nut goes on dead straight-and if threads get chewed up and you can't get it to connect straight then you'll be wanting a new valve.. icon_wink.gif
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Thu May 24, 2007 2:51 pm    Post Subject:
The point where the water is sealed off is the where the washer is - the nut just presses and holds the joint together but the threads do not seal.
An old trick is to wrap some ptfe tape around over the washer if you can pull the nut back out of the way - it seals any weak points.
Back to top
 Alert Moderators
malvo
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 29, 2007 7:48 am    Post Subject:
icon_cry.gif I've wrapped a little and then a lot of tape around the screw but to no avail, less of a leak but still there. Not cross threading and as tight as i can go.
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Tue May 29, 2007 7:59 am    Post Subject:
Did you pull the joint apart and wrap the tape around over the washer ? (wrapping around the screw threads is not the place). Do not over tighten - you will damage the screw threads on the plastic and need a new valve.
Back to top
 Alert Moderators
malvo
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 29, 2007 8:30 am    Post Subject:
icon_confused.gif don't have a washer!
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Tue May 29, 2007 8:56 am    Post Subject:
is the connector something like this :
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=92656&ts=28655
See the black bit inside the nut, that's the washer. The washer may be black rubber or red fibre stuff.
Back to top
 Alert Moderators
malvo
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 29, 2007 8:59 am    Post Subject:
yep although a more rounded top, can't remove the nut.
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Tue May 29, 2007 10:58 am    Post Subject:
you can move the nut a little way along and get at the washer - fit new washer. Buy the washer first - "1/2 inch tap connector washer "
or as someone suggested cut the pipe and put in a flexi-connector.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Tue May 29, 2007 11:45 am    Post Subject:
The nut is captive on the fitting, so it can't be removed. The washer sits over the spigot on the end of the copper pipe inside the fitting.
I would recommend replacing the washer any time the connector gets disturbed - they only cost a few pennies each.
After use they can get squeezed out of shape and wedge in the threads of the nut, and need digging out with a small screwdriver or similar. Sometimes they just fall out when the joint is dismantled.
These washers seem to be photophobic recluses - Drop one on the floor, and it immediatly makes off for the darkest remote corner it can find icon_smile.gif
You are trying to make a seal between the end of the threaded part of the ball valve and the flat area around the central spigot in the connector, not seal the nut to the thread of the connector.
The end of the ball valve spigot should be smooth and free of any nicks and dings or chewed bits of plastic that may be left from previous attempts.
Soak a new fibre washer in water for a while to soften it, clean any remains of the old washer out of the connector, push the new washer over the spigot in the connector and re-assemble. There should be no need for any PTFE tape or any other sealants. The nut should run up the threads easily by hand, and just need a tweak with a spanner to compress the washer. If it binds, check the threads are not 'crossed'
If the thread or end of the ball valve looks like something the dog has been chewing for a week, then you may need another ball valve icon_cry.gif
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
malvo
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 30, 2007 7:43 am    Post Subject:
icon_eek.gif icon_smile.gif icon_biggrin.gif icon_lol.gif SUCCESS FOLKS, many thanks to all for their advice, I have no drips, the washer was a success. I am no longer flushed with embarrassment.
Particular thanks to TicklyT also for your sense of humour, tickled mine.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Saniflo Help - Driving me nuts! 10 700 Fri May 30, 2008 9:34 am
Remounting Rads/Tail nuts and Honeywell TRVs 3 160 Sun Jul 20, 2008 9:58 am
siphon nuts? tight? 2 180 Fri May 23, 2008 12:27 pm
Where to start - Central Heating driving me nuts 5 380 Fri Mar 21, 2008 12:12 am
Basin Wrench-what type? Doesn;t fit back nuts!!! 11 2900 Mon Mar 03, 2008 12:49 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
