Joined: 23 May 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Wed May 23, 2007 12:56 pm Post Subject:
10mm to 15mm Pipe
Hi was wondering if you could answer the following question with regards to radiator replacement. I am replacing 3 of my radiators which currently use 10mm piping connecting to either ends of the radiator. I wish to replace the pipes with 15mm Chrome-plated pipe, just below the floor with compression converter fittings, will this cause any issues with regards to a drop in pressure in the system and its functionality? The current system is gravity fed from a tank in my loft. I'm assume this should be ok as it is only a 20-30cm section I'm replacing for Aesthetics sake. Your advice would be greatly received. Cheers Dave.
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Wed May 23, 2007 2:57 pm Post Subject:
I once had one look for a 36 by 18 cylinder for 15 mins before i lost the rag and told him its 3 feet high is green( foam) and holds F.ING water. And he wasn`t taking the p**s.
Joined: 20 Dec 2005 Posts: 1639 Location: Bedfordshire, United Kingdom Thanked: 0 times
Posted: Wed May 23, 2007 7:25 pm Post Subject:
Sounds like my BG days.
1/2 hour on the phone for an FFD for a cooker.
Daft bird eventually come back with "is it the chrome headed dome screw you need?")
Posted: Wed May 23, 2007 10:26 pm Post Subject:
Re: 10mm to 15mm Pipe
Cheers for your response guys. Will have a crack this weekend. Really looking forward to crawling about under the house. Might have few beers beforehand to numb the brain......
Joined: 27 Aug 2008 Posts: 181 Location: Glasgow, United Kingdom Thanked: 0 times
Posted: Sat Oct 04, 2008 11:37 pm Post Subject:
You will probably need to get the chrome off the ends of the pipe where you want to attach the compression fittings, sometimes the olives won't fit and it can be hard to get a good seal.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
