DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
45amp fuse for shower
This topic originated from the How to page called Fitting a Fused Connection Unit
Click here to return to the page called Fitting a Fused Connection Unit.
  View previous topic :: View next topic
Author Message
bluespam
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 27, 2004 3:13 pm    Post Subject:
Reply with quote Thanks
how do you wire a 45amp fuse to a consumer unit when fitting an electric shower?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ZenStalinist
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 27, 2004 3:23 pm    Post Subject:
45 amp fuse... Tell me, do you have an old fashioned 'fusebox' style CU? Or do you mean MCB?
Is the circuit on which the shower is installed already connected to the CU?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Apr 27, 2004 3:52 pm    Post Subject:
bluespam - your topic originated from the "How To" pages, but instead of the topic "Fitting an electric shower", or "Connecting circuits for shower heater units", you went for "Fitting a Fused Connection Unit (FCU)".
Are you sure you know enough to be doing this?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Apr 27, 2004 10:08 pm    Post Subject:
sorry, but from what you have asked makes me nervous, and perhaps you should call in an elctrician, it will be safer icon_cry.gif
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Apr 27, 2004 10:51 pm    Post Subject:
it depends
if you have a modern split load cu with space on the rcd side and a decently rated rcd (80A or more) then you buy a 45A mcb of the right brand clip it to the din rail in the rcd side screw it to the busbar wire the live to the mcb the neutral to the neutral bar for rcd cuircuits (if you aren't sure which is which follow the other wires for breakers on the rcd side)
if you have a modern rcd only cu with a rcd rated at 80A or more and a space then proceed as above
if you have a modern switch only CU with a switch rated at 80A or more then you can use a 45A rcbo (again fo the right brand) theese clip to the rail in the same way as mcbs but have a black wire you conenct to the neutral bar and a cream wire you conenct to the earth bar. live and neutral of the outgoing cable go to the rcbo and earth to the earth bar
if you have a modern split load cu with space on the non-rcd side and a main isolator rated at 80A or more then you can fit a rcbo on the non-rcd side as described above
note that some brnads don't make 45A breakers so you may need to spec your cable for being on a 50A one if 40A is insuffican't for your shower
if your cu does not match any of theese descriptions then you should use a seperate shower unit like this
http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=05435&id=69659
(you can change the mcb to a 40A if suitable)
you will need to henly block it into the tails this is done as follows
fit a double pole henly block to the fuseboard
http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=05950&id=14850
PULL THE SERVICE FUSE
remove the tails from the meter to the existing cu
use fresh 25mm red and black double insulated tails to rewire the cu's
connect meter to henly block
conenct henly block to main cu
connect henly block to shower cu
and put the service fuse back
the main switches in both cus should be off when handleing the service fuse to reduce the risk of arcing
feel free to post a picture of your cu
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 27, 2004 11:22 pm    Post Subject:
Plug..will you not post pictures of Volex stuff without a warning in big red letters..I nearly fainted from fright icon_biggrin.gificon_biggrin.gificon_biggrin.gif
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Apr 28, 2004 9:57 pm    Post Subject:
Pulling the service fuse best done by REC.........
Back to top
 Alert Moderators
Juno 60
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 29, 2004 2:08 pm    Post Subject:
I fitted a dedicated shower CU for my 9.5kW using exactly the process described by Plugwash. All hunky dory so far, no trips and no discernible voltage drop when I fire it up.
Back to top
 Alert Moderators
bungle29
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 07, 2004 9:09 pm    Post Subject:
Add on to main unit
im looking to put a shawer in but theres no spaces on the main board is there any way i can put a rcd on by wireing from the main board trip switch sorry about the spelling could some one help ????? thanks guys !!!!!!!!!
_____________________________
email address removed (email addresses can be viewed in your profile)
Moderator
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Sep 07, 2004 11:44 pm    Post Subject:
That's exactly what plugwash describes above.
If you're not looking at that post and thinking "Ah yes, that's all pretty obvious" then you should be thinking "Ah yes, I'd better get an electrician".
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
new hob blowing 45amp fuse,gashed finger,hit head help!! 11 620 Tue Mar 04, 2008 8:17 pm
Upgrade base fuse of new CU from 45amp to 60amp 9 480 Wed May 06, 2009 10:06 pm
45amp pull cord 2 360 Wed Oct 27, 2004 7:42 pm
30amp to 45amp 20 680 Fri Nov 28, 2008 6:11 pm
45amp Ceiling Pull Cord Switch keeps blowing 5 260 Sat Jan 24, 2009 8:00 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
