DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
No hot water/heating
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Wicca
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 26, 2007 11:14 pm    Post Subject:
Reply with quote Thanks
Hi
I have no hot water coming out of my taps and my heating will not come on without being completely turned off and back on again.
I have a Baxi Combi 80e boiler, one of the lights is flashing indicating fault on pump or low pressure. The pressure does seem to be below 0.5 which is from what I can gather not a good thing.
Do I need to get an engineer out to have a look, does anyone have an idea as to what it might possibly be.
Help from a very confused female that has learnt a lot about boilers in one evening.
Edited to add....
Have repressurised boiler up to 1 but light is still flashing.....
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sun May 27, 2007 9:17 am    Post Subject:
SO if you turn the boiler off at the wall, it then works fine on CH?
WHat happens if you open a hot tap while the CH is on?
Back to top
 Alert Moderators
Wicca
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 27, 2007 10:23 am    Post Subject:
If I turn it off completely and then back on, the heating starts up and I will also get hot water from the taps.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Sun May 27, 2007 6:21 pm    Post Subject:
For a start you should repressurise to about 1.6 Bar.
Tony
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ideal Response water heating - more problems 16 1060 Fri Mar 23, 2007 8:07 pm
Sunvic 207XL heating/hot water programmer 6 4160 Mon Mar 19, 2007 6:29 pm
Central heating not working on Potterton (hot water is ok) 13 2940 Sun Mar 18, 2007 9:07 pm
Hot water but No circulation on Central heating? 10 1440 Fri Mar 09, 2007 9:31 pm
hot water but no heating 4 260 Mon Mar 26, 2007 1:42 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
