Creda washing machine stopped spinning
1 Jan 2005
Our Creda machine gets a lot of use and has gradually stopped spinning on all programmes over the past week.
The drum turns fine although the washing does have some dirty marks on it.
Any ideas re the no spin??
You say the drum turns fine? Is this by hand or does it turn when it's washing?
Most likely causes, sump hose filter blocked, carbon brushes in motor worn.
You'll have to elaborate on the dirty marks, this can be caused by several things including, no maintenance washes carried out, bearing seal leaking.
The motor turns the drum ok when it's washing but then it won't spin.
The dirty marks are darkish as if there is something in the machine that is leaking out- poss bearings?/
