Joined: 27 May 2007 Posts: 4 Location: Avon, United Kingdom Thanked: 0 times
Posted: Sun May 27, 2007 2:42 pm Post Subject:
Changing 1 Gang to 2 Gang Switch
I currently have my kitchen ceiling light on a single switch, Can I swop this for a 2 gang switch and add my low voltage U/Cabinet lights. These do not have an independent live supply.
Joined: 10 Aug 2004 Posts: 302 Location: Staffordshire, United Kingdom Thanked: 2 times
Posted: Sun May 27, 2007 3:04 pm Post Subject:
Unless their is a neutral connection at your switch then No ,, you may be lucky and find that the feeds have been looped in the switches, but then you probably wont only option in this case is to either put a fused spur on your ring main and then use that as your mains supply for them , or rewire the switch line to provide a neutral at the switch position.
Posted: Sun May 27, 2007 3:08 pm Post Subject:
If you ease the switch forward then you might or might not see a couple of black cables in a connector block in the back of the box, if not, then you have no neutral.
Posted: Sun May 27, 2007 3:12 pm Post Subject:
No you do not have a neutral, the black should be marked as a red, the power comes to the switch on the red core, then returns to the light on the black core, In your case you have no Neutral at the switch .
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
