Flush wall boxes
yes, but the box sinkers are expensive £80 - £100. Not really worth it if your not going to use it much. Use a cold chisle.
all very well and good to say use a bolster/cold chisle but when the block is as hard as nails...Can u hire an SDS drill bit???
Well, as I said they're called box sinkers. Ring you local hire shop and find out!
cheapest way is to get a box which you drill through to honeycomb.
Look in Argos catalogue- they do them.
I recently hired an SDS drill with rotary stop (needed if using box sinker bit!, 110V transformer and the sinker bit from my local Protrade.
I think it cost about £18 for the day
:rolleyes: :D :rolleyes: :rolleyes: they are very useful things to have if you say use them everyday you can buy the whole set from screwfix.com for £189
