DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fused Connection Unit
This topic originated from the How to page called Fitting a Fused Connection Unit
Click here to return to the page called Fitting a Fused Connection Unit.
  View previous topic :: View next topic
Author Message
jonjon
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 27, 2004 10:32 pm    Post Subject:
Reply with quote Thanks
I have just fitted a FCU to the wall next to the electric cooker, but the red indicator light stays on whether the switch is in the on or off position. What have I done wrong - all the connections seem to be right and the cooker is working. Thanks! icon_redface.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Apr 27, 2004 10:38 pm    Post Subject:
Just a wild guess, but I'd say that you've connected the supply to the load terminals and the load to the supply terminals. The switch will still work, i.e. it will make and break a connection between supply and load, but the light will stay on all the time as it is connected to the load terminals. Let's hope you haven't also got Live and Neutral on the wrong sides..
BTW - what circuit is the FCU connected to, and what is it supplying via what size fuse through what size cable?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
jonjon
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 29, 2004 7:42 am    Post Subject:
Thanks - I will look at the connection again and will answer the second half of your response---later! icon_rolleyes.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Switched Fused Connection Unit + Oven 6 3160 Tue Jul 19, 2005 10:59 am
Is there a double sized fused connection unit available?? 5 500 Wed Jul 13, 2005 9:40 pm
Help on requirement for a switched fused connection unit 4 380 Fri May 30, 2008 1:06 am
Fused Connection Unit with a single socket 2 120 Mon Nov 09, 2009 5:07 pm
Fused Connection Unit 10 700 Mon Sep 19, 2005 11:11 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
