DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Alternate Metal post anchors
This topic originated from the How to page called Different ways of anchoring the fence posts
Click here to return to the page called Different ways of anchoring the fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
  View previous topic :: View next topic
Author Message
mjhenks
from United States of America
Thanked: 0 times
PostPosted: Tue May 29, 2007 3:42 am    Post Subject:
Reply with quote Thanks
What are your thoughts on Using Simpson Strong Ties as fence anchors. Want to install a 42" picket fence (72" between posts) using there LCB posts and rotate them 90 degrees each post to maximize the strength. I also want to space the post 1" above ground to minimize rot. I would use bolts to fasten the post to the anchor.
Thanks for the input.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Deluks
from United Kingdom
Thanked: 24 times
PostPosted: Tue May 29, 2007 10:44 am    Post Subject:
Can you not get metposts in the US? As these are designed for the application you describe.
Back to top
 Alert Moderators
mjhenks
Thanked: 0 times
PostPosted: Tue May 29, 2007 1:54 pm    Post Subject:
Yes, you can get these but they are more expensive then what you can get at from Simpson Strong Tie. ($8 vrs $17 ea) Seams like the only real differance is that these support the post on all 4 sides where the Simpson tie is only on two sides.
Back to top
 Alert Moderators
randomthinking
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 1:12 am    Post Subject:
mjhenks: can you share where these (Metpost Bold Down) can be found in the US (Seattle)?
Thanks much in advance - Steve
Back to top
 Alert Moderators
jmfraz
Thanked: 0 times
PostPosted: Wed Sep 12, 2007 2:03 am    Post Subject:
ground spikes in the US
I'm not sure why ground spikes are not as readily available in the US as the UK. I have also been looking for some. I just saw some on eBay
http://cgi.ebay.com/24-METPOST-SUPPORT-SFP24-accepts-4x4-post-NIB_W0QQitemZ330068865844QQihZ014QQcategoryZ20505QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
If that link doesn't translate, try item # 330068865844
I also saw that 84 Lumber carries the StrongTie version of ground spike, so if you have that store in your area it might be worth a look.
Good Luck
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
Bolt-down fence-post anchors 8 1020 Tue Apr 24, 2007 7:27 pm
How strong are concrete-in metal fence post supports? 5 660 Mon May 11, 2009 10:10 pm
Metal Fence Post Anchor 3 340 Tue Jul 08, 2008 11:52 am
Metal Post Spikes 3 13380 Thu Aug 18, 2005 4:13 am
Please recommend me a relatively good metal shed 15 1140 Wed Dec 17, 2008 4:58 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
