Hi, don't know if anyone has any tips for this but...
I'm in the process of fitting out an ensuite showeroom. It's quite small so, I want to put mirrors on 3 walls to give the illusion of space.
The mirrors themselves will run in a band around the room and the largest will be about 1.5m long by 750mm. I plan to fix them with mirror mate type adhesive.
My question is, what can I do to make the corners look neat. My first thoughts where to just but the mirrors, at right angles and then run some clear silicon down the joint but, I keep thinking there must be a neater and more profesional way to finish the corners.
Any ideas? All input greatfully received!
Cheers
Symo
Cheers
Symo
