DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
central heating
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
wmvej01
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 29, 2007 12:37 pm    Post Subject:
central heating
Reply with quote Thanks
Cold radiators, The system is on an electonic timer for water & heating, it would appear that the radiators will only work when the system is heating the water, once the water is hot enough the radiators go cold ! pump seems to be ok as does the thermostat also no air in rads or pump, header tank also ok, not sure about the y valve, system has been ok for a couple of years and timer also seems ok, Help
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Tue May 29, 2007 1:06 pm    Post Subject:
Either a faulty 3 port valve or it's wrongly wired, which is very common.
see http://content.honeywell.com/uk/homes/Catalogue/Sundial%20Plans/3.4%20Y%20Plan.pdf
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 10 times
PostPosted: Tue May 29, 2007 9:47 pm    Post Subject:
I would agree with ChrisR.
Sounds as though the valve is either moving to the CH position but not firing boiler because there is no output voltage from the valves orange wire due to faulty microswitch within valve head.
Or the valve is not moving to the CH position to trigger the microswitch, this could be a fault in wiring where there is no power on the grey wire of the valve which is needed to drive the motor from mid position to CH position.
Or motor within valve faulty and unable to overcome the resistance of the fairly strong return spring.
You should be able to remove valve head off spindle and try the various positons and verify the various movements. Only expect valve to move after few seconds delay. Also! if at CH positon and you switch off both HW and CH dont expect valve to move at all. It will not move from CH until HW is called for. Of course if all power is removed from programmer, the grey wire becomes dead and in this condition valve will return to start positon ie HW.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Central heating ok but no hot water. Zone valve problem? 5 380 Fri Apr 25, 2008 7:31 am
Ripping out central heating 18 740 Fri Apr 25, 2008 4:38 pm
central heating controller 2 200 Mon Apr 21, 2008 9:01 pm
New central heating system 3 260 Mon Apr 21, 2008 1:11 pm
Noise of central heating pump vibrating through my wall! 7 1340 Sun Apr 20, 2008 3:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
