Joely
Joined: 29 May 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Tue May 29, 2007 6:00 pm Post Subject: 2 lights 1 dimmer |
Advice please..
I need to run two light fittings each with 7 x 10 watt 12 G4 bulbs on one dimmer switch? They have transformers. What type of dimmer switch do I need?
Heard lots about buzzing dimmers and overloading so want to avoid expensive mistakes.
Thanks |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Tue May 29, 2007 6:25 pm Post Subject: |
check the transformers can be dimmed first (it will be printed on it) __________________ Do you like music Mr Finch?
Forum = Opinions |
Steve
Joined: 15 Apr 2005 Posts: 12857 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Tue May 29, 2007 9:26 pm Post Subject: |
If the transformer is round and heavy, dont try dimming it, they are not normally suitable for the task. If you can, remove the transformer and fit a small electronic one, which can be dimmed.
Anyhow, if the tx's are suitable for dimming, you'll need 280 watts of dimming minimum. |
Joely
Posted: Fri Jun 01, 2007 8:52 pm Post Subject: |
Thanks for your replies.
I checked one of the transformers and it doesn’t say if it is dimmable or not, but in NEXT directory (where I purchased light fittings) it said must use NEXT halogen dimmer switch so assumed that it is. I looked at the transformer and it is electronic.
Purchased a 400W/VA Intelligent Dimmer Switch (because we didn’t want the NEXT shiny chrome one) and light fitting buzzed!
Husband is cheesed off and we are now thinking about going back to a regular switch.
What are we doing wrong? Why the buzzing? |
