DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Shower bar thermostat fitting
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
mdrandall
from United Kingdom
PostPosted: Wed May 30, 2007 9:17 am Reply with quote
Is it normal practice to fit a shower bar type thermostat to the tiles but sticking with mastik. I know there are special nrackets available but out builder reckons sticking it is normal.
The reason I ask is that our thermostat has come loose and the plumber has just returned to stick it up again. I caught sight of the pipes inside the wall and they are not screwed down at all. He reckoned that this was the standard thing to do.
Also the thermostat drips like mad when switched off. The plumber reckoned the "cartridge" could be changed but it would probably go again. His suggestion was to change the whole thermostat for around 100 - the shower is less than 3 years old !!!!
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 801 times
PostPosted: Wed May 30, 2007 12:37 pm Reply with quote
The cheaper bar type showers often did not have any fixing brackets/points to fix to the wall. You were relying on the pipe work in the wall to hold them in place and the silicone seal that makes the shower/wall water proof.
Back to top
 Alert Moderators
mdrandall
from United Kingdom
PostPosted: Wed May 30, 2007 1:02 pm Reply with quote
So is it normal practice to stick them on?
The valve has two chrome cone shaped parts covering the pipes and these are the only bit that actually touches the tiles. So the mastik has to grip a thin circle of metal.
The builders plumber has now restuck the valve to the wall but I am concerned that it will come away again.
It also seems very difficult to add a bracket afterwards as this involves removing the tiles (unless someone has a better idea).
Any information gratefully received.
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 360 times
PostPosted: Thu May 31, 2007 7:05 pm Reply with quote
These are ideal.
Back to top
 Alert Moderators
mdrandall
from United Kingdom
PostPosted: Thu May 31, 2007 11:11 pm Reply with quote
They look like the bits I need. Does anyone know how they are fixed to the tiles?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fitting a thermostat shower to a combi boiler 3 1020 Sat Sep 15, 2007 5:51 pm
Fitting an external thermostat for a gas boiler - possible? 10 820 Sat May 24, 2008 5:44 pm
Fitting a room thermostat 2 260 Wed May 07, 2008 11:10 am
advice needed on fitting a DANFOSS thermostat 4 760 Wed Jan 09, 2008 1:23 pm
Fitting a central heating room thermostat 4 1340 Wed Aug 27, 2008 9:54 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
