DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Super Quilt loft insulation
This topic originated from the How to page called Loft Insulation
Click here to return to the page called Loft Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
RichardWhitaker
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 31, 2007 11:45 am    Post Subject:
Reply with quote Thanks
I am in the process of installing Super Quilt loft insulation (http://www.ybsinsulation.com/superquilt14.htm) which lines the roof and is attached to the rafters, secured with batons (as per manufacturer's instructions). Do I need to remove the old fibre glass insulation from between the joists below in order for the new insulation to work properly or can I just leave the old stuff in place?[/url]
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu May 31, 2007 11:54 am    Post Subject:
leave the old stuff unless it is full of vermin.
The more insulation you have, the better.
p.s. I find it difficult to grasp how it can be
"25mm thickness - approximately equivalent to 200mm mineral wool/fibre"
How much does it cost?
Back to top
 Alert Moderators
RichardWhitaker
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 31, 2007 5:00 pm    Post Subject:
Thanks for that John. I got it for about £120+VAT per 10m x 1.5m roll.
Back to top
 Alert Moderators
freedy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 29, 2007 11:26 am    Post Subject:
Just come across this question.
I have recently moved in to my present address & I also want to put this stuff across my rafters, but whoever had the roof retiled never had any roofing felt put on underneath, so I am looking at bare tiles. icon_confused.gif
Will it make any difference to the insulation other then the back of it getting dirty? Or will I be wasting my time & money on it?
I understand from a couple of roofers that felt cant be put on now without the whole roof being taken off to do it. icon_sad.gif
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 24 times
PostPosted: Mon Oct 29, 2007 2:06 pm    Post Subject:
You can put anything under the rafters to keep the roof clean without going to all this expense. Brown building paper or the foil backed bubblewrap would be more suitable.
The superquilt will need an airspace and layer of plasterboard for it to match 200mm quilt. Much cheaper to use normal loft insulation between the joists.
Back to top
 Alert Moderators
freedy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 29, 2007 3:00 pm    Post Subject:
Thanks for your answer but I may have picked on the wrong thing. This is what I was thinking of using.......... http://www.thermawrap.co.uk/loft_wrap.html
Does this make your reply different?
Back to top
 Alert Moderators
Janeelliott
from United Kingdom
Thanked: 0 times
PostPosted: Wed Dec 26, 2007 10:24 am    Post Subject:
super quilt
Where can I buy super quilt? There are loads of web sites telling me all about it but not how much it costs or where I can obtain it.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Tri iso super9 /super quilt 14 2 2000 Fri Mar 10, 2006 10:34 pm
Boarding out loft after insulation 13 3540 Wed Sep 26, 2007 8:37 am
Loft insulation under existing boards 7 13240 Tue Oct 02, 2007 9:20 pm
Loft storage and insulation 3 800 Fri Oct 19, 2007 8:30 am
Pre-winter Loft insulation 5 840 Mon Sep 24, 2007 8:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
