diynutter
Joined: 02 Jun 2007 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Sat Jun 02, 2007 11:46 am Post Subject: Earth Bonding - Gas Meter |
The gas board have just been out to try and fix a gas leak I have and have now put a warning on my meter saying that it isn't earthed.
Could someone advise how I earth it please. I have searched the net and it appears I need to run a earth cable from the house side gas pipe back to the consumer unit but I can't find anywhere what size cable I should use.
Any help much appreciated |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Sat Jun 02, 2007 12:32 pm Post Subject: |
usually 10mm in a private house. A single run with no cuts and joins. Show us a picture of your electrical incoming supply cable, service head, main fuse and consumer unit for more advice. |
chicd4
Joined: 22 Apr 2007 Posts: 41 Location: London, United Kingdom Thanked: 0 times
Posted: Sat Jun 02, 2007 10:31 pm Post Subject: |
10mm earth cable attached to the pipework within 600mm of the meter on the users side, and before any tees in the supply. Run all the way back to the main earthing terminal. ( usually located by the consumer unit) |
Taylortwocities
Joined: 27 Jul 2006 Posts: 4932 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Sat Jun 02, 2007 10:57 pm Post Subject: |
.... connected to the gas pipe using an earthing clamp conforming to BS951....... __________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R. |
Chri5
Joined: 19 Jan 2007 Posts: 1827 Location: London, United Kingdom Thanked: 28 times
