DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
excessive run on?
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
gadz
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 05, 2007 12:34 pm    Post Subject:
excessive run on?
Reply with quote Thanks
I have just had new 'swan neck' type taps (Norrie from Magnet) fitted as part of a new kitchen. I didn't know and wasn't warned that this style of taps suffers from run on, ie the water continues to pour out after the valve is closed. The problem is that it continues to run on for between 12 and 18 seconds which I consider excessive. I've done a timed study and taken movies but Magnet regard this as 'slight' and to be expected. I'd appreciate hearing about other peoples experiences as I can't work out whether this is 'normal' or if there is a fault with the tap. Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jun 06, 2007 12:20 am    Post Subject:
I would regard 12 to 18 seconds as abnormal and excessive, not to mention intensely annoying.
However, you might struggle to get resolution with the manufacturer, but if you act swiftly you could return the taps to the supplier and argue that they aren't fit for purpose - you might be covered by some kind of 'satisfaction guarantee' that many retailers provide these days.
Back to top
 Alert Moderators
gadz
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 06, 2007 7:58 am    Post Subject:
thanks softus, might just try the 'satisfaction' thing.
Back to top
 Alert Moderators
gadz
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 11, 2007 7:43 pm    Post Subject:
update: I received a new end piece that screws on the spout from the tap importers, it included what appears to be a fine mesh gause. It has stopped the run on for the last few days. Only time will tell.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Keston 60 excessive pressure 4 260 Thu Jan 15, 2009 3:53 pm
Excessive vibrations of floor caused by washing machine 19 3020 Fri Jul 25, 2008 12:22 pm
Trianco 12/14 excessive hot water temp 12 380 Sat Apr 26, 2008 6:44 pm
BBU Excessive hot water on gravity 4 200 Tue Jan 20, 2009 8:58 pm
Excessive gas consumption 59 1200 Sun Feb 08, 2009 4:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
