DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Lintel choice
This topic originated from the How to page called Rendering
Click here to return to the page called Rendering.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
booky1
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 06, 2007 5:26 pm    Post Subject:
Lintel choice
Reply with quote Thanks
I\\\'m building an extension that will be externally rendered and would like the decorative stone lintels above the windows to be flush/slightly proud of the render. Do I buy the standard 100mm thick lintel and set it 20mm forward of the outer block leaf or do I need a 120mm thick lintel? I\\\'d appreciate any advice.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mikric
from United Kingdom
Thanked: 3 times
PostPosted: Wed Jun 06, 2007 5:51 pm    Post Subject:
just use normal lintol (catnic etc) and sit decorative head forward 20 mm is how i usually do it . icon_biggrin.gif
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 72 times
PostPosted: Wed Jun 06, 2007 8:36 pm    Post Subject:
agree with the above.
any decoration, be it corner stones, keystones, lintels, quoins, ashlar etc, can be achieved either with the render itself or with 'stuck on' decoration.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 52 times
PostPosted: Wed Jun 06, 2007 9:58 pm    Post Subject:
I would say that it is the decorative lintels which should be thicker so that they are flush with the back of the external leaf and project past the render.
Don't forget to prop the lintel in the centre!
Back to top
 Alert Moderators
booky1
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 07, 2007 3:30 pm    Post Subject:
Thanks for your comments. I should have said that I didn't intend using a steel lintel as I did'nt want to see the 30 or 40mm of steel protruding beyond the face of the window frame (the windows don't have the traditional extended head detail with drip groove etc so the steel won't be completely covered).
I intend the decorative cast stone lintel to be load bearing - does this change your advice?
Back to top
 Alert Moderators
mikric
from United Kingdom
Thanked: 3 times
PostPosted: Thu Jun 07, 2007 7:28 pm    Post Subject:
You would be better to ask the manufacturer of your stone lintols about your query. Most decorative stone heads,cills etc do use steel in their construction but you will need to find out if they are suitable for bearing loads.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 52 times
PostPosted: Thu Jun 07, 2007 11:37 pm    Post Subject:
Yes, most decorative lintels only have steel in them to stop them breaking in transit or when installing - they may not be load bearing - even for their own weight
If you are not using steel lintels because you dont want to see them, then what are you doing about closing the cavity, and avoiding any ugly joint of infill material and the feature lintel?
Back to top
 Alert Moderators
booky1
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 08, 2007 9:25 am    Post Subject:
Again, thanks for your comments. I had intended to specify load bearing lintels when I placed the order.
I'm trying to achieve a couple of things with this arrangement. Firstly, I want to use independant lintels on the inner and outer leaves of the cavity wall to minimise cold bridging. The intention is to fit cavity closers at all positions (top, bottom & both sides) within the window opening and sit the window frame in the outer leaf overlapping the closers by about 20mm (the frames are 70mm deep). Internally, the closers should provide a good base for plastering the reveals. I intend to fit a rigid cavity tray over the lintel with stop ends and weeps etc.
Secondly, I want to avoid seeing any exposed steelwork. If I used a standard independant steel lintel in the outer leaf to support the decorative lintel it should stop about 5mm from the outer face. This would mean that about 45mm of the steel lintel will project beyond the window frame.
If anyone can suggest a better way of avoiding cold bridging, avoiding exposed steel lintels and having the decorative lintel 20mm proud of the wall to allow for rendering ---- I'd appreciate your views.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Lintel choice for attic window in gable end wall 2 300 Sun Nov 16, 2008 6:19 pm
What's everyones choice of gripfill/adhesive 2 680 Wed Feb 15, 2006 10:33 pm
Lintel material type for underground use 7 180 Thu Mar 05, 2009 4:46 pm
Lintel above doorway 3 120 Sat Feb 28, 2009 9:44 am
Box lintel vrs RSJ ? 12 440 Sun Mar 08, 2009 12:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
