DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Two rads on with HW only !
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
lauriedthompson
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 07, 2007 5:19 pm    Post Subject:
Reply with quote Thanks
Hello,
When I switch the hot water on two rads ( One downstairs in the conservatory and one in a bedroom ) heat up. Can anyone explain what might be happening and whether I can sort it myself?
Regards
Laurie
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Jun 07, 2007 5:28 pm    Post Subject:
Have you got a room thermostat?
What options does your CH timer/programmer have?
Photos would be helpful.
Do some of your radiators have thermostatic valves?
Back to top
 Alert Moderators
lauriedthompson
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 07, 2007 7:22 pm    Post Subject:
Hi John,
Thanks for the reply. We do have a room thermostat located in the living room. I change the programmer myself ( the plumber told me it was a simple process ) from a old glowworm to a Drayton Tempus 7. The boiler is a Vulcan Continental. None of the radiators have thermostatic values although all can be shut down.
Most of the radiators have been replaced over the years, but the two that are heating up have not.
Does this help? do you still want photographs?
Kind regards
Laurie
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Jun 07, 2007 7:51 pm    Post Subject:
I expect you have a motorised valve beside either the boiler or the hot cylinder, that sends the primary circulation around the cylinder and/or the rads.
Quite likely this is worn (allowing hot circulation to escape and go round those rads) or faulty (not closing properly.
If you can find the electric valve and see how many of the pips connected to it are hot, this will give you a clue. The pictures will help us see how the installation is done.
I have never had to fix a 3-port valve but someone will be along in a minute who knows the drill (I amnot a pro).
look for
with two or three large copper pipes going into it and an electric cable.
there is also a possibility that your programmer of room stat are calling for Heating.
As one of the hot rads is downstairs I think it is a worn 3-port valve, not gravity circulation.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
rads heating on the top only 4 140 Mon Feb 25, 2008 12:29 pm
HELP ! ! ~ air in system ~ bleed weekly ~ rads now cold 3 300 Thu Feb 28, 2008 8:21 pm
Drained Heating system- Now rads are only warm. 12 340 Mon Mar 03, 2008 9:19 am
no heat to rads but water is hot hot hot 9 400 Wed Feb 13, 2008 5:28 pm
potterton netheat problem with water and rads to work to get 5 220 Sun Feb 10, 2008 7:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
