splinter73
Joined: 02 May 2004 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sun May 02, 2004 10:19 am Post Subject: wall insulation |
i am changing my garage in to a room.
the walls are single brick. what is the best way for me to insulate the walls and what will i need to use |
nstreet
Joined: 22 Nov 2003 Posts: 1761 Location: United Kingdom Thanked: 0 times
Posted: Sun May 02, 2004 10:49 am Post Subject: |
I not an expert, but the way I would do it would be to place timber battens on the existing walls, use rockwool or similar insulation batts between these, and line with plasterboard. You may need some sort of moisture barrier, perhaps one of the more qualified members can advise.
Have you infomed your local planning dept that you are proposing to do this? |
splinter73
Posted: Sun May 02, 2004 2:42 pm Post Subject: |
i have aplied for planning and it all ok
do i need to have any sort of cavity between the isulation and outside walls |
masona
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
sidney
Joined: 01 Oct 2005 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Sat Oct 01, 2005 8:07 pm Post Subject: Re: wall insulation |
Hi Splinter
Have completed your room in the garage, as I am thinking of doing the same, but only half of it.
S
| splinter73 wrote: | i am changing my garage in to a room.
________________________
moderator
please note 17 which is here |
