No Hot Water - Ferroli Medone 80E
8 Jun 2007
Gloucestershire
I have a combi boiler which has been playing up for a while in terms of its supply of how water - sometimes it is fine, but most of the time the hot water would come and go - particularly annoying in the shower
Anyway, yesterday morning it stopped supplying hot water at all and I thought I would finally have a bit of a closer look.
It seems to be failing to register that the demand for hot water has been instigated and hence it doesn't fire up and start heating the water.
Tests this morning:
Heating off, hot tap on - no response
Heating on, hot tap on - hot water led on then burner on
Heating on, hot top on - no response
(and so on with no response)
It seems like the one time I got hot water was a fluke and this is not going to sort itself out.
I was wondering if anyone had experienced anything similar and what the fix or cost to fix might be - Britich Gas quoted £144 for an all inclusive fix.
My boiler is a Ferroli Medone 80E, and any help would be greatly appreciated.
Cheers
Stu.
It could well be the flow switch but while its open check the two temperature sensors as they seem to be a common failure point on your model.
Tony
If the little led for the dhw does not come on then the first check is the dhw flowswitch and the filter into it.
They do fail.
I`ve even had new one`s straight out the box faulty.
The switch can be stripped down and the shaft of the wheel greased.
Paul
