DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Two switches
This topic originated from the How to page called Adding a spur to a ring circuit from a junction box
Click here to return to the page called Adding a spur to a ring circuit from a junction box.
  View previous topic :: View next topic
Author Message
nikkirobinson
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 08, 2007 10:41 am    Post Subject:
Two switches
Reply with quote Thanks
I am spurring off the ringmain with a junction box, and then I have two appliances that I want to switch from this spur (both low current).
Do I have to wire 2 separate switched fused spurs?
Or can I wire a single un-switched fused spur connected to a double switch plate with each appliance connected to these?
Or are there any other options.
Thanks in advance!
Nik.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Fri Jun 08, 2007 12:48 pm    Post Subject:
You can have spur from a ring final into a double socket outlet.
The cable from the ring must be the same size as the cable in the ring.
Or you could have a switch fused spur (FSU) on the ring. From the output of this FSU you can have any numner of sockets. The load on the additional sockets will be limited by the fuse in the FSU (max 13A)
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
nikkirobinson
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 08, 2007 1:01 pm    Post Subject:
Two switches
Thanks for these suggestions.
The, two appliances are a projector and a screen for a home cinema system, so the power cables will be wired directly into these appliances, run through the roof and then down to some switch/spur arrangement at the back of the room.
So I don't really want sockets running off the spur, so can I do it similar to your second suggestion, but instead of a number of sockets off the spur have to switch plates?
Cheers,
Nik.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Fri Jun 08, 2007 3:34 pm    Post Subject:
Sure, no probs.
__________________
TTC
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Splitting 2 lights with 2 common light switches 5 540 Wed Dec 19, 2007 6:24 pm
Earthing Antique Light Switches 3 320 Sun Dec 09, 2007 2:22 pm
2 way light switches - help 4 260 Wed Nov 28, 2007 2:07 pm
Do PIR Light Switches work? 3 300 Tue Nov 13, 2007 1:53 pm
light switches 15 1020 Sat Dec 22, 2007 5:50 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
