Joined: 17 Oct 2006 Posts: 17 Location: United Kingdom Thanked: 0 times
Posted: Sun Jun 10, 2007 12:12 pm Post Subject:
Install shower switch
Hi just wondering if i could get some help with installing a shower switch, say i have my two Live wires (red), my two Neutral (black) and two earth (green/yellow), how are these connected to the four points of the shower switch? The switch has two connetions to a Load, and two to a Feed, which wires should be connected to thse points? Thanks
Joined: 27 Jul 2006 Posts: 4932 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Sun Jun 10, 2007 12:17 pm Post Subject:
I am concerned that if you need to ask this very basic question are you sure that you should be doing the work where you will be inroducing a mix of electricity and water?.
There are other things to consider as well: equipotential bonding, RCD, notifiactaion to the lacal authority to comply with the law, current loading and much more.
To give u a start though...
The live and nuetral Feed are, well, the feed. Umm that means the cable coming from your consumer unit.
The live and neutral load are, well, the load. Umm that means the cable going to the shower.
The two earth conductors (green/yellow) will go into that handy terminal marked 'earth'.
__________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Posted: Sun Jun 10, 2007 2:00 pm Post Subject:
All i want to do is replace the existing shower switch, surely there can't be that much danger with that, seeing as all other installations have already been complete?
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Sun Jun 10, 2007 2:32 pm Post Subject:
Yeah, as Taylor says above, connect the red and black wires in the cable to the shower to the Load L & N, connect the red and black wires in the cable from the consumer unit to the Feed L & N. Both earths (and prossibly a supplementary bond) connect to the earth terminal.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
