Joined: 10 Jun 2007 Posts: 2 Location: New Zealand Thanked: 0 times
Posted: Sun Jun 10, 2007 11:46 pm Post Subject:
Dimmer switch to heated towel rail
I am building an airing cupboard. Since we have instant hot water I have no cylinder to make use of. A mate suggested I use a heated towel rail and control the temperature of the towel rail via a dimmer switch, to save money and stop overheating in confined space.
I have the following:
1 heated towel rail rated: 65Watts
1 dimmer switch rated: Max load: 500Watts(incandescant), 400Watts (dichroic), Min load: 75Watts, Rated 500VA
Again my mate suggestes the load of 65MW being less than min load of 75Watts should be no problem and will be 100% safe, is this true?
Not that I don't trust my mate but a second opinion is always re-assuring.
Replies appreciated.
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Mon Jun 11, 2007 4:21 am Post Subject:
Re: Dimmer switch to heated towel rail
Presuming thats a typo( watts not megawatts), or your cupboard is going to get rather warm , but why the dimmer unit? I would not have thought it was needed on heater that small.
Joined: 11 Jan 2004 Posts: 16485 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Mon Jun 11, 2007 8:26 pm Post Subject:
Don't you just rub two sheep together to keep warm?
About the "dimmer", don't use a standard one. Dimplex make a special one just for their towel rails which turns down the heat - the surface temperature gets surprisingly high & where they are unshielded and installed in premises used by the infirm or disabled, it is necessary to be able to limit the surface temperature to prevent burns.
__________________ As George Michael once said, "..if you're gonna do it, do it right, right?"
Posted: Wed Jun 13, 2007 3:07 am Post Subject:
Not so "Dim" thanks to your advice
Will start with a simple switch to see how much warmth the towel rail creates in the confined space. Then as suggested will decide between a thermostat or a timer. Almost all replies appreciated, I might live in NZ but I'm British, why do you think I came to you guys for advice!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
