Jeremyb123
Joined: 01 Nov 2006 Posts: 8 Location: Berkshire, United Kingdom
Posted: Tue Jun 12, 2007 3:50 pm |
The existing Potterton room stat has stopped working, and when the radiators come on they are boiling hot.So when I\\\'ve gone to replace the stat, I\\\'ve noticed that the existing one , as well as live & neutral, has a H for heating, which my replacement does not have, it just has a terminal for L & N, the three, numbered 1,2 & 3. Do I need to replace the stat with a Potterton like for like ? |
gas4you
Joined: 23 Feb 2007 Posts: 16902 Location: Norfolk, United Kingdom Thanked: 491 times
Posted: Tue Jun 12, 2007 5:16 pm |
Neutral will remain the same, Live will be live from programmer/timeswitch and the 'heating' will be the switched live from the new stat back to the zone valve or pump. Instructions with new stat should tell you what switched live is. |
ricicle
Joined: 14 Sep 2006 Posts: 6034 Location: Gloucestershire, United Kingdom Thanked: 342 times
Posted: Tue Jun 12, 2007 5:49 pm |
The room stat does not control the temperature of water in the rads.That is the job of a stat on the boiler. |
Jeremyb123
Posted: Mon Oct 22, 2007 2:08 pm |
| gas4you wrote: | | Neutral will remain the same, Live will be live from programmer/timeswitch and the 'heating' will be the switched live from the new stat back to the zone valve or pump. Instructions with new stat should tell you what switched live is. |
Thanks.
I've replaced the stat with the Potterton model the supplier said, so all works fine....... except that whenever I put the hot water on, on it's own, the radiators come on as well ???? |
Steve3948
Joined: 10 Oct 2007 Posts: 152 Location: United Kingdom
Posted: Mon Oct 22, 2007 7:26 pm |
| ricicle wrote: | | The room stat does not control the temperature of water in the rads.That is the job of a stat on the boiler. |
It does control the temperature of the water in the rads by opening and closing the 3 or 2 Port Valve.
The boiler stat controls the temperature of the water in the main flow and return. |
Steve3948
Posted: Mon Oct 22, 2007 7:31 pm |
| Jeremyb123 wrote: | | gas4you wrote: | | Neutral will remain the same, Live will be live from programmer/timeswitch and the 'heating' will be the switched live from the new stat back to the zone valve or pump. Instructions with new stat should tell you what switched live is. |
Thanks.
This could be a 3 or 2 Port valve problem, with a micro switch stuck or broken, unless it's a combi.
Do you know what system you have, Combi, Y-Plan, S-Plan, C-Plan ????? |
