DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
spotlight wiring
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
shadwell69
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 13, 2007 12:06 pm    Post Subject:
spotlight wiring
Reply with quote Thanks
I have a wiring nightmare with two 3-way spotlights.
One light is simply wired off a black wire /red wire (earth cut short) and works fine.
The second light in the room has 2 cables coming out of the ceiling, each cable has a black wire red wire and the two earths connected together. Tried connecting two reds into brown lightwire and two blacks into the blue. Fuse blew on upstairs light circuit. What am I doing wrong please?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Chri5
from United Kingdom
Thanked: 28 times
PostPosted: Wed Jun 13, 2007 3:47 pm    Post Subject:
Sounds like a switch wire issue.
Try wiring just one set of wires on 1 twin and earth to the light. Does the light stay on?
If not try the other set, one or other will be the true LN feed.
Once this has be sussed, you need to terminate the live cable N to the lamp, the L then needs terminating to the L / red of the other cable. This then sends the L down to the switch and the N side of this cable becomes the switched live and is terminated on the L of the lamp.
The switched live should be sleeved in brown sleeving for future ID, a bit of ins tape with a marker pen is sort of ok.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
wiring a spotlight after removing fluorescent tube 3 300 Mon Nov 03, 2008 11:24 pm
fitting a spotlight - wiring issue? 5 800 Mon Jul 02, 2007 10:39 pm
12v Outside GU10 LED SOFFIT SPOTLIGHT WIRING ??? 7 4380 Mon Apr 30, 2007 10:24 pm
Wiring A Spotlight From A Switch To A Plug 2 420 Sun Nov 18, 2007 9:40 pm
wiring a spotlight in a conservatory. 6 640 Sun Aug 12, 2007 8:06 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
