DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
vented central heating
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Amikom
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 17, 2007 8:41 am    Post Subject:
Reply with quote Thanks
We recently had a leak in the ch system which brought the ceiling down !!! System drained and leak fixed but when trying to refill ch system no water coming to rads!! The expansion tank in roof is full though - assumption we have blockage in feed pipe! The question I have is do we just get someone to fix the blockage or, as suggested by them, change the system to an un-vented system? If so approx how much would that cost? BTW we have a megaflo hot water system if that makes any difference.
Any help would be most appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
charlieboy3
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 17, 2007 9:13 am    Post Subject:
blocked cold feed
the chances are that the cold feed is blocked, the most likely place for this is where it enters into the system. You are most likely to see a 15mm pipe cold feed, and a 22mm pipe open vent join the system just before the pump. the blockage will be where the 15mm connects.
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 17, 2007 10:49 am    Post Subject:
You can't just seal any system first & foremost the boiler must have an o/heat stat but you may also need to change rad valves to meet 3 bar pressure
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Jun 17, 2007 7:22 pm    Post Subject:
Megaflo is nothing to do with the heating side. As previously stated cold feed blocked or you need a boiler with an overheat stat.
Removing cold feed blockage is a hell of a lot cheaper than converting to a pressurised system.
As you obviously have not filled the system yet, how do you know you have fixed the leak icon_rolleyes.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
moliver34
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 17, 2007 8:24 pm    Post Subject:
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Sun Jun 17, 2007 8:27 pm    Post Subject:
moliver34 wrote:
Ahhh the water regs method
Section 4 paragraph 2 clearly states
"before refilling a system after a repair you must say the following
"a blind man would be pleased to see it"
"s** it that will have to do its me darts night"
and finally before turning on the water
"right not sure of this one have the wet n dry ready"
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Sun Jun 17, 2007 9:10 pm    Post Subject:
Even if it did have an overheat stat the heat exchanger may not be rated to carry a pressure of up to 3.5 Bar.
It needs to have the manufacturers approval to be used in an unvented system.
Tony
Back to top
 Alert Moderators
Amikom
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jun 19, 2007 8:03 am    Post Subject:
Thanks guys for all the comments - most helpful.
Agreed gas4you, we don't know the leak is fixed yet, so haven't put the ceiling back up yet! Agreed the Magaflo does not affect the ch but thought it may have affected the pipework. Will call the plumber in to find the blockage in the cold feed to the rads and get that fixed.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Central Heating Open vented - Air problem 28 1140 Mon Sep 01, 2008 6:11 pm
Vented central heating system 21 1720 Tue Feb 21, 2006 3:50 pm
Gas central heating - open vented system design fault 8 860 Sun Jan 20, 2008 11:43 am
Adding senitnol x100 to open vented heating system 17 500 Tue Jan 20, 2009 4:09 pm
Vented heating system will not refill 4 380 Tue Nov 18, 2008 11:56 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
