hi there ive just put a new motor in machine but still wont turn it lights up ok and the programer moves but the motor wont turn thank you hoover am 110 six
I have a Hoover AM120, it must use the same board as the AM110. Drum would not spin or wash until I'd re-soldered three pins under the black relays, there's not enough copper around the pins, one of them is particularly bad and only solderable where the track meets the pin.
