DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
post anchoring
This topic originated from the How to page called Different ways of anchoring the fence posts
Click here to return to the page called Different ways of anchoring the fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
Guest
Thanked: 0 times
PostPosted: Sun Mar 24, 2002 7:19 pm    Post Subject:
post anchoring
Fence post anchoring in existing concrete block retaining wall.
I would like to replace a post that was anchored via a (now eroded and broken) embedded L-shaped steel brace in a concrete block retaining wall. How to I embed another steel brace in the wall without damagining the retaining wall?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Fri Apr 26, 2002 3:49 pm    Post Subject:
Re: post anchoring
Here are two suggestions:
a) Saw off old bracket. Drill (bore) a 1 3/4 inch hole in concrete approx. 10 to 12" into top of wall. Install and Epoxy a 1 3/8" galvanized pipe into hole. Drill a 1 3/8 hole using ships auger into bottom of post. Approx. 10 to 12" deep. Drop post on pole. Your done.
b) Saw off old bracket. Drill a 3/8" hole approx 6" deep into concrete. Expoxy a threaded foundation bolt into wall. Use a Simpson Strong Tie "U" bracket and bolt in place.
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Wed Sep 25, 2002 3:36 pm    Post Subject:
Re: post anchoring
Can you tell me how to batten posts when
they have been sumnk in concrete. What do I use and how many etc ?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
FENCE POST ANCHORING 7 10760 Fri May 12, 2006 8:21 pm
4x4 post anchoring to wood balcony 2 5000 Thu Jul 21, 2005 5:11 pm
Anchoring bookcase to stud partition wall 6 900 Wed Jan 23, 2008 10:50 pm
where to find concrete fence post 4 800 Sun Feb 24, 2008 2:44 pm
B&Q corner wall cupboard...fitting the corner post!!!! 4 560 Fri Aug 21, 2009 5:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
