DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Partially filling Wall Cavity
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
Remoh1
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 21, 2007 5:06 am    Post Subject:
Reply with quote Thanks
Hi all
looking to laminate the front room floor, we have patio doors at one end installed by the previous owner. in front of these is a block of wood over the cavity, then carpet. i want to put laminate right up to the patio doors is it safe to fill the cavity with self leveling concrete up to the level of the concrete floor that is under the carpet in the rest of the room?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Remoh1
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 18, 2007 10:43 am    Post Subject:
Re: Wall Cavity & laminate flooring
Remoh1 wrote:
Hi all
has no one got an answer or a suggestion
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 41 times
PostPosted: Sat Aug 18, 2007 1:44 pm    Post Subject:
Depends what damp proofing there is to stop the screed getting wet, if the screed's effectively going fill the gap between between the outer and inner skin there'd be nothing stopping the screed and consequently the inner skin from getting damp, if that happens your lovely new laminate may also get wet, de-laminate and get ruined. Can you post some photies?
Back to top
 Alert Moderators
Tony Gallagher
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 18, 2007 9:27 pm    Post Subject:
1) Are your patio doors sitting entirely on the outer leaf of the cavity or are they central so as to overlap the cavity?
2) The doors will have a sill and possibly a sub sill. If it is one sill then it will be wood or UPVC which sheds the rainwater clear of the wall. If there are two sills then the first will shed onto a second, probably concrete sill, and that one sheds clear of the wall. Which do you have?
3) Is the DPC level of the floor the same as the DPC level of the cavity walls?
5) Are all your ground floors concrete?
6) How much above ground level is your floor level?
If the installation is correct then the door frame should cover the cavity in which case the inner edge of the sill should have bridged leaving only the top of the inner brick skin to be filled by you - similar to the diagram. It sounds like your door is not like this but is fitted on the outer leaf. It is not a good idea to fill the cavity but it should not be difficult to get around....Let me know what you have got.
Tony
Back to top
 Alert Moderators
willp2
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 15, 2007 4:48 pm    Post Subject:
I read your reply to the cavity problem, I have the same situation but my patio door is now internal due to new conservatory, I am presuming bridging the cavity will not be a problem due to it not being an outside wall. will ya let me have your thoughts please
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 73 times
PostPosted: Mon Oct 15, 2007 5:14 pm    Post Subject:
all you need to do is make a 'trough' with dpm, and fill in with concrete or screed.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Filling Cavity to Improve Sound Insulation 3 520 Sun Aug 19, 2007 4:22 pm
Help needed with filling a cavity 2 240 Tue Jul 01, 2008 12:13 pm
filling stud cavity 4 440 Tue Sep 04, 2007 8:32 pm
Cavity Filling, Nose have a look 12 420 Thu Jul 10, 2008 12:17 pm
Advice on filling a 15 Inch deep hole in wall 6 500 Mon Jul 07, 2008 7:07 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
