Joined: 22 Jun 2007 Posts: 125 Location: Leicestershire, United Kingdom Thanked: 0 times
Posted: Fri Jun 22, 2007 7:09 pm Post Subject:
Socket Positions
Hi all.
I'm currently completely rewiring my old 1930's semi. My question relates to the position of the sockets.
1 - Is it true that as it is an old house, the height requirement of between 450mm and 1200mm doesn't apply or is that wrong if I'm doing a total refurb?
2 - I read somewhere that the sockets must be a certain distance from the corners of the room. Is this true?
Joined: 14 Sep 2006 Posts: 3488 Location: Gloucestershire, United Kingdom Thanked: 19 times
Posted: Fri Jun 22, 2007 7:14 pm Post Subject:
Is it a total rewire or just some additions? If additions then I would put them the same as the others (unless they are at a ridiculous height)
There is no criteria on distance from the corner of a room but common sense is needed (ie not butted right up against the corner or terminating will be awkward)
EDIT: Too slow for Davy
__________________ Empty barrels make the most noise.
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Fri Jun 22, 2007 7:37 pm Post Subject:
(1) you might be an old person who has got used to sockets low down, to give them a better chance of being clouted by hoovers, furniture etc.
However now that all new work, and a lot of renovation, is done at the new heights, people are coming to get used to it, and will look at your low sockets and think they look weird. They will also think the electrics are due for renewal as they must be quite old.
Also, the higher sockets are more convenient for the older person, the overweight person, the person with a bad knee or a bad back, or the pregnant person.
Posted: Fri Jun 22, 2007 7:39 pm Post Subject:
How many of these attributes are applicable to you MrD
Posted: Fri Jun 22, 2007 7:47 pm Post Subject:
Brilliant. I'll put the sockets at the new height. I was a little unsure at first thinking they may look weird, but I suppose if this is standard, it's better that way.
My main concern was putting the sockets near a corner. Obviously I'm not going to put then butting up to another wall, but thought I read somewhere that they had to be at least a metre away from a corner. This was giving me difficulties on walls with chimney breasts etc, so am quite pleased to hear I have made this up!
Thanks everyone for your help.
By the way, I'm over weight, and the wife is pregnant, so 450mm is sounding better all the time!!
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Fri Jun 22, 2007 7:51 pm Post Subject:
Otoh i'd take a mixture of heights in the same room as meaning someone weired had been working on the electrics.
Plus putting sockets higher up is far more work than putting them in just above skirting level.
Posted: Fri Jun 22, 2007 7:54 pm Post Subject:
Joined: 01 May 2005 Posts: 58 Location: Durham, United Kingdom Thanked: 0 times
Posted: Sun Jun 24, 2007 9:51 am Post Subject:
The distance from the corner of a room comes from BS8300 which requires a minimum distance of 350mm from the corner to outlets, switches or controls. Hower Approved Document M doesn't seem to mention this.
Posted: Sun Jun 24, 2007 5:18 pm Post Subject:
It's in Approved Document M, 4.30, paragraph G.
However, Approved Document M also says they can't be any lower than 400mm, not 450mm.
I'm having this work inspected by my local council, so want to make sure it's right. Is it best to call them to see what they want?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
