thermostatic mixer shower temperature problem
22 Jun 2007
I just installed a new shower upstairs hot water from combi boiler. it is hard to control the water temperature by using the thermostatic control knob. when it goes hot I turn the knob to cold a bit. it will go so cold. vice versa. it is hard to get the right point to make the water warm. any idea please thanks
when I set the shower temperature to a certain degree . the downstairs one will be the same.
I don't understand your second post.
Are you sure you have the hot and cold the right way round? Hot should be on the left.
not sure, I will check it today. the second one is , for example, if I set the shower temperature to 30 degree. there is another shower downstairs. that one will be under 30 . no matter how to adjust the hot water knob. it cannot reach any hotter.
