el patron
Joined: 23 Jun 2007 Posts: 4 Location: Hampshire, United Kingdom Thanked: 0 times
Posted: Sat Jun 23, 2007 9:37 am Post Subject: towel rail |
i have a fan heater in my bathroom that i want to get rid of and extend the cable down to a towel rail. the fan is fed from a fused spur outside the bathroom but off the lighting circuit . so is it ok to feed a towel rail off a lighting circuit or do i need to come off the ring or a separate radial from the fuse board |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Sat Jun 23, 2007 9:42 am Post Subject: |
No
Yes with a fused spur (the switch outside the bathroom)
If you want to but a spur is usually easier.
If you are in England or Wales this is notifiable work as it is in the bathroom, and you will find it easier and cheaper to get a professional electrician to do it for you. The "earth" bonding of the bathroom may need to be brought up to scratch for safety. ask around friends and neighbours for a recommendation. When phoning ask if he is a member of a self-certification scheme and will leave you a certificate when finished (the correct answers are yes and yes). |
