DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
FUSE ON CU BLOWING
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
NOTASPARKY24
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 24, 2007 10:31 pm    Post Subject:
FUSE ON CU BLOWING
Reply with quote Thanks
Please can some one help i woke up this morning to find my downstairs lights didnt work i checked the CU and the Fuse had blown so i replaced the fuse and it blew again after rougthly 5 mins. I have a small tester and it seems i have a live to earth short and was wondering if anyone could please explain how this would happen and how i go about resolving it as i really am scratching my head with this one and am quite desperate to get it resovled. Also I have had no work done in my house diy etc they just all of a sudden didnt work. I'd be greatful for any information thanks..
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 24, 2007 10:33 pm    Post Subject:
It's probably a loose live conductor touching a metal backbox/light fitting, Turn off the 'leccy and check all the switches/fittings.
While you are going around checking, tighten up all the terminal screws and check everything is correctly sleeved.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Jun 25, 2007 1:26 am    Post Subject:
the first thing to do is inspect everything on the circuit for obvious issues. Fixup anything like lack of earth sleeving, wires fallen out of terminals, obviously damaged insulation (cover it with sleeving) etc.
If the fault is still there after you've done that you will have to split the circuit into sections and test each individually until you find the problem.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Mon Jun 25, 2007 6:46 am    Post Subject:
If you have any downlighters in a ceiling have a look at them for cable melted by the heat of the lamp.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon Jun 25, 2007 6:57 am    Post Subject:
Also worthwhile checking for water in an outside light. Any signs of a leak anywhere inside?
Back to top
 Alert Moderators
NOTASPARKY24
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 25, 2007 7:25 am    Post Subject:
FUSE BLOWING
Thanks everyone I have taken down the lights and found that all my earth wires in my light fittings do not have sleeves. Would this most likely be causing the problem??
Back to top
 Alert Moderators
Moderator 5
Moderator Comment
Posted: Mon Jun 25, 2007 10:55 am    Comment:
I have deleted your enormous duplicate post.
Rupert
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Mon Jun 25, 2007 8:44 am    Post Subject:
Quite possible if they are shorting to a live terminal.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Jun 25, 2007 10:16 pm    Post Subject:
Re: FUSE BLOWING
If they touch something live then it would cause the trips. Fix that issue and then if you still have the original problem start looking for other ones.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Extractor fan, 3 amp fuse in FCU keeps blowing 7 520 Sun Jan 06, 2008 9:23 pm
fuse blowing 6 660 Mon Aug 29, 2005 4:50 pm
Please Help ! Strange problem with FUSE ! keeps blowing 7 760 Sun Aug 26, 2007 8:47 pm
Fuse Blowing Regularly 16 540 Fri Jan 25, 2008 5:42 pm
Fuse keeps blowing 7 400 Tue Jul 10, 2007 7:19 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
