| Author |
Message |
Toocheaptopaysomeone
Joined: 28 Jun 2007 Posts: 8 Location: United Kingdom
Posted: Thu Jun 28, 2007 7:06 pm |
I am replacing the syphon on my toilet. Bought exactly the same one so know it is the correct type. I took out the old one and am trying to fit the new one but it just refuses to go it the hole. Tried hammering it in but don't want to break it. Any tips on how to install.
Thanks |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
clf-gas
Joined: 02 Mar 2007 Posts: 3453 Location: Lancashire, United Kingdom Thanked: 63 times
Posted: Thu Jun 28, 2007 7:18 pm |
| Quote: | | I am replacing the syphon on my toilet. Bought exactly the same one so know it is the correct type. |
Ok good
| Quote: | | trying to fit the new one but it just refuses to go it the hole. |
Now not so good
| Quote: | | Tried hammering it in but don't want to break it. |
Getting worse
| Quote: | Any tips on how to install.
Yes, Put the hammer away, now get the corrct syphon in the morning  |
| Back to top |
| Back to top |
clf-gas
Posted: Thu Jun 28, 2007 7:27 pm |
Have you compared the outlets, your new one seems larger.
Will it not work in using a screwing motion.....OOPS  |
| Back to top |
JohnD
Joined: 15 Nov 2005 Posts: 34364 Location: Hampshire, United Kingdom Thanked: 1089 times
Posted: Thu Jun 28, 2007 7:31 pm |
the new ones all deformed out of shape where it's been hammered. |
| Back to top |
Posted: Thu Jun 28, 2007 7:35 pm |
I have compared them and they are definitely the same. The old one took a bit of effort to get out because it's supposed to be tight isn't it? I had to break it up to get out! Maybe the wrong one was in to start with
The new ones not out of shape at all. Maybe I need to hammer harder! It doesn't screw in as there is not enough space in the cistern to rotate it. |
| Back to top |
JohnD
Posted: Thu Jun 28, 2007 7:42 pm |
can you post some photos?
Youve got the cistern out, and removed the rubber washer? |
| Back to top |
Posted: Thu Jun 28, 2007 7:52 pm |
The syphon is a shires twinflow syphon. There is one for sale on e-bay if you want to look at it.
I've got the thing in most of the way now. The rubber washer is in place but there is about 1/4 inch left to get in so the cistern won't leak. I think I just need to give it a good wack! |
| Back to top |
gas4you
Joined: 23 Feb 2007 Posts: 16909 Location: Norfolk, United Kingdom Thanked: 503 times
Posted: Thu Jun 28, 2007 7:55 pm |
You don't by chance mean you are trying to put the donut into the bottom of the cistern instead of on the outside?? |
| Back to top |
clf-gas
| Back to top |
Posted: Thu Jun 28, 2007 8:33 pm |
Dave,
I don't quite understand what you mean. The syphon is one part - it doesn't separate so I am unsure about what you mean by the donut |
| Back to top |
JohnD
Posted: Thu Jun 28, 2007 8:41 pm |
here's your ebay photo, but I'd be interested to see a pic of how you're fitting it into your cistern. Especially as the advertiser says
"No need to dismantle cystern.
Can be serviced in 5 mins"
| Back to top |
Posted: Thu Jun 28, 2007 9:02 pm |
I've taken a picture of the cistern but have no idea how to up load it - I'm a bit of a technophobe! I think the problem is that the syphon should be screwed in but I can't be physically srewed in because there is not enough room to rotate it in the cistern. I think I will give up and call a plumber! |
| Back to top |
gas4you
Posted: Thu Jun 28, 2007 9:08 pm |
Syphon should just push into hole in bottom of cistern, with a thin rubber seal, or silicone, between it and the cistern, this is then held in place by the large plastic nut that is screwed up under the cistern, after the metal 'bolt holder' if it is a close coupled cistern and pan. |
| Back to top |
JohnD
Posted: Thu Jun 28, 2007 9:15 pm |
| Back to top |
