Joined: 30 Jun 2007 Posts: 2 Location: Nottingham, United Kingdom Thanked: 0 times
Posted: Sat Jun 30, 2007 12:33 pm Post Subject:
Deaf doorbell
I have just removed a \\\'deaf doorbell\\\' which dims the lights when pressed. I am now left with 2 core and 3 core wires with earths and am not sure how to connect these up to restore the lights both up and downstairs. Please can anyone help???
Joined: 03 Nov 2006 Posts: 3611 Location: Bedfordshire, United Kingdom Thanked: 22 times
Posted: Sat Jun 30, 2007 1:19 pm Post Subject:
Can you post a photo of the units you removed ? Or post any details of maker type etc etc.
Are the up-stairs and down-stairs light on the same fuse / MCB
Is there a junction box close to the consumer unit with the three core cable from the unit going to it. A twin and earth into the consumer unti and one of more twin and earths going into the house.?
If it is the type I have seen then a removal of the three core and a change of one wire in that junction box is all that is needed.
Joined: 20 Nov 2005 Posts: 207 Location: Kent, United Kingdom Thanked: 0 times
Posted: Sat Jun 30, 2007 1:20 pm Post Subject:
I ran across one of these recently, that had been installed by the RNID.
It was basically an electronic switch that was wired between the lighting circuits and the mcbs.
What you will probably need to do is identify which circuit/circuits are feeding the lighting circuit and then connect those directly to the mcb. That will likely be the 2 core cables - the 3 core is likely to be related to the switch and can probably be ignored.
The key is to identify the cables that feed the lights..
Gavin
EDIT: Bah, too slow
__________________ foolproof systems underestimate the ingenuity of fools
Joined: 29 Jun 2007 Posts: 117 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 01, 2007 9:55 am Post Subject:
But how do they know if there's someone at the door in the day time, or do they have the lights on all the time - must be an expensive option.
Surely a wireless system connected to a vibrating allert would be better?
Posted: Sun Jul 01, 2007 10:44 am Post Subject:
I recall the one system I saw put a 5 amp diode in series with the lighting when the door bell was pressed. This dimmed all the lights.
There was a "half live" ( half wave via another diode) that was energised when the bell was pressed. This "half live" went to light switches in some rooms. These switch were two way. ON put the common (switched live to the lamp) to the normal live and OFF put the common to the bell operated "half live".
Very "Heath Robinson" as I recall but it worked. Only problem was the 5 amp diode needed replacing by a 10 amp.
Posted: Sun Jul 01, 2007 9:54 pm Post Subject:
The one I saw worked purely as a switch in the lighting circuits. So the lights had to be turned on during the day, and the unit set to DAY mode. Then the lights were normally off, but flashed when the doorbell was pressed. There was also a NIGHT mode on the unit, which I didn't investigate, but I suspect it worked the other way round.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
