Source old fasioned "on top" sink and plumb to was
1 Jul 2007
Berkshire
Hi all.
Two questions, if anyone can help?
1. I'm trying to source a double bowl kitchen sink with drainer for customer job. Google has many. However, I have issue with very little space for supporting kitchen chassis and any worktop. Sinks found so far are all inset and need minimum 1200mm worktop - leaves me with huge worktop cutout and tiny borders (waste of material, cost and time!!! Looking for possible supplier that may still stock old-fashioned "on top" sinks that used sit on top of and cover the whole of a 1000mm base unit and require no worktop. Anyone know what they are called and any suppliers?
2. Also, connecting sink to waste. The only waste closeby is a down pipe for external surface water off the school roof and into a closed\sealed drain. Can I connect to this? School kids only using bio-degradeable paint stuff etc.
Cheers,
Neil
Don't know about number 1.
If it is just surface water drain then no. Waste must go into the main drains for 'dirty' water.
Cheers for replies\info.
1. "DOH!". Found out just after this post such sinks are called "sit-on". Found one internet supplier. Catering units mega expensive!
2. Waste routing: Am providing a new second sink, some 5-6 metres away, from an existing sink, it's waste drops straight into a pipe set into concrete floor! Will need to try to route new waste passed a large radiator that has only minimal clearance underneath at skirting level. If route impossible, and not enough angle of decline, then I assume the only other possibility is route up through ceiling void, then drop down to existing and fit an electric pump and valve? Sorry, not much experience at this, but seen similar for lavatory waste (macerator?)
Cheers,
Neil
